68HC11 simulator
Old May 29, 2004 | 01:50 PM
Pyle's Avatar
68HC11 simulator
I have been using a 68HC11 simulator program to help me understand the assembly language. The demo version has memory restrictions and I can only play with pieces of code at a time.
I'm curious if anyone else has used an emulator program like this to test code on? And would I even be able to test the full source code using something like this?
At the very least, its a nice tool for understanding the assembly language since you can step through the code one line at a time and see how its modifying the registers, memory, stack etc.
http://www.hc11.demon.nl/thrsim11/info.htm
Old May 29, 2004 | 07:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I think there are some freeware simulators as well. I downloaded one but didnt really do much with it. You could also use a test bench and an ecm. Thats what I did. I first started experimenting with code by writing small stand-alone algorithms that did some basic stuff like trigger outputs or relay calculations via the outputs.
86IROCZ
DIY PROM
Dec 2, 2004 06:35 PM
white88formula
Dec 22, 2003 11:45 PM
18436572
DIY PROM
Dec 14, 2003 10:33 PM
smithtc
Aftermarket Product Review
Dec 8, 2003 10:35 AM
JPrevost
Jul 14, 2003 07:35 AM
