ALDL Cable
Old Mar 20, 2002 | 08:16 AM
Agent-Z28's Avatar
ALDL Cable
Ok i made this aldl cable and here are the readings i got someone please help figure out what I did wrong.
All I had were the first two rows in raw data on the program WINALDL nothing else showed up.
The numbers were
Promida promidb
0.2 252 0 0 0.0 0 0.0
0.4 90 255 0 0 0.0
0.9 255 0 0 0.0 0
1.4 223 143 0 0 0.0 0
1.7 65 0 0 0.0 0 0.0
1.9 90 255 0 0 0.0
2.2 255 0 0 0.0 0
2.7 223 255 0 0 0.0
3.2 254 131 0 0 0.0
3.4 90 255 0 0 0.0
Old Mar 20, 2002 | 08:38 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
That looks like it reads some bit's wrong and starts over.
Someone said that it only worked when the laptop was fully charged. When the battery was below half he got communication problems.
I don't reccomend using 12 V from the car to power the laptop because that could induce noice into the communication lines.
I have a bad battery in my laptop and I bought a small motorcycle battery that I use to power it.
Perhaps your serial port does not deliver good 12v on pin 4. You could try a different power source.
Old Mar 20, 2002 | 09:28 AM
Agent-Z28's Avatar
What would you suggest as a diffrent power source.
Old Mar 20, 2002 | 10:14 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Lighter outlet for testing if that is the problem
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
