AFR at 11.08 at WOT? Is this too low?
Car: Red Rooster
Transmission: M5
I need some opinions guys. I did some testing last night and this is what I noticed:
RPM - 3275
MAF - 134 gps
KM/H - 127
Coolant Temp - 80 C
Total Spark Advance - 32
KNOCK RETARD - 9.4 d
O2 - 990mv
Cell # 15
BLM/INT - 128
LV8 - 197
PW - 11.08
From my little experince and little research i think that the PW is too rich. Should't it be like 12.5 at WOT?
Also what would cause soo much retard?
These numbers are when i was in 4th gear and I stepped on the gas. It was on a flat road, just me in the car.
Cold night, -20C, 1200 AM.
I am looking for sugestions/opinions.
Thanks.
RPM - 3275
MAF - 134 gps
KM/H - 127
Coolant Temp - 80 C
O2 - 990mv
Cell # 15
BLM/INT - 128
LV8 - 197
PW - 11.08
Thanks.
Car: An Ol Buick
Engine: Vsick
Re: AFR at 11.08 at WOT? Is this too low?
RPM - 3275
MAF - 134 gps
KM/H - 127
Coolant Temp - 80 C
O2 - 990mv
Cell # 15
BLM/INT - 128
LV8 - 197
PW - 11.08
Thanks.
RPM - 3275
MAF - 134 gps
KM/H - 127
Coolant Temp - 80 C
O2 - 990mv
Cell # 15
BLM/INT - 128
LV8 - 197
PW - 11.08
Thanks.
I don't see anything that indicates a 11.08 AFR.
You have to look for answers on the retard. too much timing, or not enough fuel generally are the causes. BUT mechanical noise can trigger the K/S ie an exhuast rattle.
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
RPM - 3275
MAF - 134 gps
KM/H - 127
Coolant Temp - 80 C
O2 - 990mv
Cell # 15
BLM/INT - 128
LV8 - 197
PW - 11.08
Thanks.
RPM - 3275
MAF - 134 gps
KM/H - 127
Coolant Temp - 80 C
O2 - 990mv
Cell # 15
BLM/INT - 128
LV8 - 197
PW - 11.08
Thanks.
If it's taking out 9 degrees and you're only getting 32 degrees total, that means that the spark advance table is requesting 41 degrees at that point. You need to back off your spark advance at that area in order to keep it from taking out too much.
Car: Red Rooster
Transmission: M5
Sorry i forgot to add the AFR from the excel chart.
It shows 14.71 all the time but at that example above it shows
AFR of 11.17
The PW was 11.08
Is that too rich?
Grumpy and Greg thanks for your suggestions.
BTW, I have my base timing set to 9d, and using a stock chip.
AFR of 11.17
The PW was 11.08
Is that too rich?
Engine: 385 HSR
AFR of 11.17
The PW was 11.08
Is that too rich?
AFR of 11.17
The PW was 11.08
Is that too rich?
The bumped-up base timing is probably what's causing the knock retard since you were actually trying to run 44 degrees of spark advance at WOT at mid-rpm. Most engines can't handle that much s.a. in those high-load conditions, hence the knock and retard.
355tpipickup
Sep 13, 2015 11:35 PM
