Holley Maifold
Old Sep 26, 2002 | 03:09 PM
MericanMuscle's Avatar
Holley Maifold
I think i got my mind set on the holley intake mainifold for the 670 tbi i will be getting but im still not so sure. ive heard of hood clearance and egr problems. I need something that is smog legal and that will pass emissions. If anyone can goive me some advice i would be pretty happy.
Old Sep 27, 2002 | 12:13 AM
iroc22's Avatar
Holley makes a 4bbl carb manifold that you can use an adaptor plate on and will fit the stock hood and has EGR. I cant remember the part number but I can get it to you soon....
Old Sep 27, 2002 | 07:55 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
iroc22
if you do manage to come accross that part number please post it, I am interested in the same one.
Old Sep 27, 2002 | 12:51 PM
iroc22's Avatar
Holley Stealth PN#7525 has EGR and frt manifold height of 3.5" and a rear of 4.5" which will fit perfectly. The only problem with this manifold is that it's only available for the pre 86 intake bolt pattern; so unless you're changing your heads or wanna modify the ones you're using, then you can't use that intake. There's also PN#300-64 which is a dual plane instead and will fit the stock heads (intake bolt pattern). The height however is 3.68" front and 5.02" which will be a squeeze to fit under the stock hood. You will probably have to remove the insulation and maybe run a lower height air cleaner. Both manifolds will require a 4bbl to TBI adaptor plate. Holley makes one, but it's way more economical to make your own outta some plastic.
Old Sep 27, 2002 | 02:16 PM
How is the projection maifold holley makes?
Old Sep 27, 2002 | 03:47 PM
iroc22's Avatar
They're fine, but they're pretty tall for a stock Firebird/Camaro hood.
Old Sep 27, 2002 | 04:17 PM
I was plannin on goin with the PN#300-64 manifold but is there anyone who has tried using it, problems and what not? Also will a 14 by 3inch drop base aircleaner fit.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
