Air conditioning just doesn't do anything anymore
Old May 22, 2004 | 04:01 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Had my 89 2.8L firebird for about 3 years now. A/C worked just fine up until last year autumn. One day it started pouring in the afternoon (as it does every day here in south florida ) and I kicked on the defrost. I was using the air before the storm, but after the 20 minute downpour and everything was hot and sticky, I turned the A/C back on to find it just blew hot air. Been like htat ever since.
Is there a fuse besides one in the passenger fuse block?
Any ideas why it would just quit, (and while I'm using defrost?)
I'm not at all good with A/C, but I did check the pressure with one of those silly on can refill gauges and it read towards the red on the gauge (50psi or so if i remember right.)
Any pointers on troubleshooting or where to start?
For what its worth it used to make a noticeable dip in RPM and I could "hear" the A/C compressor while it was on. I get nothing like that now... Just a tiny dip in voltage due to the fan that disappears when the fan is off.
Old May 23, 2004 | 03:10 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Check and see if your clutch is activating when you turn on the ac. If its not make sure all of the switchs and wires are ok.
If the clutch is activating, then you most likely have a bad compresser.
Old May 23, 2004 | 06:25 PM
bobdole369's Avatar
Car: 1989 Firebird
nope
I see nothing at all move when I turn on the AC, all the wires are plugged in and everything.
Old May 26, 2004 | 12:53 AM
DENN_SHAH's Avatar
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
2 quick things to check, 1 with the key on engine off, turn your ac on & put a screw drive against to ac compressor clutch, if you feel the clutch seems to pull the screw drives to it & the clutch isn't engaged, give it a tap on the front, if it engages then you'll need to set the air gap. if not, then #2, with the screw driver lightly tap on the low pressure switch, they go out alot, if the clutch kicks in, then the switch is bad, if not you can jumper across the low pressure switch & see if it engages, if it does check to see if the a/c is charged. if the a/c is charged the switch is bad. the low presuure switch in on the accumulator.
Old Aug 15, 2004 | 01:04 PM
bobdole369's Avatar
Car: 1989 Firebird
Nope
No, and No. clutch doesn't engage at all. Doesn't seem to pull the screwdriver to it at all. I tapped on the low pressure switch, and got nada.
Old Aug 17, 2004 | 11:45 AM
Beefy89's Avatar
Unplug the low pressure switch and jump it with a paper clip, then try again. If that doesnt work then check for voltage on that same plug. If theres voltage there than it's probably the compressor.
Old Aug 17, 2004 | 06:39 PM
bobdole369's Avatar
Car: 1989 Firebird
Should've thought to do that myself... <smacks forehead>
Will do so tonight.
Vintageracer
Jan 10, 2020 05:33 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
jackhammer
Aug 15, 2015 10:04 PM
