Adjusting driver's side door ?
Just wondering if there's a way to adjust, or align the doors on our thirdgens. I'm pretty sure there is, so I guess what I'm asking is how do I do it? Should I replace these bushings that I keep hearing about? Thanx for any help.
That is kinda hard to answer. The door will be impossible to align perfectly if the hinge pin bushings are bad, because the door will sag down. If your door isn't sagging, you can adjust your door by loosening the upper and lower hinge bolts and slide it to where it needs to go. You'll need a friend to help you with this though.
Car: 1985 Camaro
Engine: ......
Transmission: ......
i just did it to my right side door.it helps A LOT if you use a car jack.put a towel on the lifting surface as to not scratch the paint.Then lift the jack till it just touches the bottom center of the door.then loosen the top and bottom bolts,and jack the door to the desired height,then re-tighten.It may take a few trys,but it worked for me.You'll want to do it with the door as shut a possible,but still open enough you car get a wrench in to loosen the bolts(this makes it easier to lift the door.)
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Wow, really old thread.
Anyways, my driver's door, besides sagging (don't feel any important need to fix it at this time if it's only going to happen again in a short while), needing weatherstripping (bad..really bad), has a 1/8" gap between the outer panel of the door and and quarter panel at the hinge area. It's like it's closed too far inwards towards the center of the body. Is there any way to fix this?
Engine: 2.7L V6
Axle/Gears: 4.41
I know someone here has had to do this at one time or another... How can I move the latch portion of the door out a measly 1/8 inch?
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Sounds like you need shims or?
If your bushings/Pin on the bottom are worn, it will be very difficult to line up the door. They are only about $15 bucks at any auto parts store, so I would recommend swapping them out.
If the front of your door is too far inwards from the fender, first check the flange under the fender rear lip that bolts to the body (under the car). If you bottom out on something and smash these things, it often tweaks the bottom of the fender out. Just get some vise grips or something and tweak it back until it aligns better.
If that isn't it, you need shims between your door hinges and the body. You will have to remove the inside kick panel to loosen the bolts. Check a junkyard car to see what they look like (C-shaped, so you don't have to remove the bolts completely)
Good luck
Troy
So Cal
Good luck
Troy
So Cal
Engine: 2.7L V6
Axle/Gears: 4.41
It's not the HINGE end that's off, it's the LATCH end...
Imagine this: Door -_ quarter panel. The - is the door and the _ is the quarter panel. Any questions class?
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Engine: 2.7L V6
Axle/Gears: 4.41
YES, I need new bushings. NO, that IS NOT the problem. All of the gaps are FINE. The problem is that the door SHUTS TOO FAR TOWARDS THE CENTER OF THE BODY. Viewing from the top, again: Door -L QUARTER PANEL! Not FRONT FENDER, QUARTER PANEL!
Would a new set of weatherstripping help this? Mine is like, well, GONE.
Car: 1982 Z-28
I installed new weatherstripping on my '86 and the door rattle stopped. The weatherstrip is the only thing that keeps the door tight against the striker. I believe new weather stripping would help a lot in you situation.
Car: 1982 Camaro Z28
Engine: 305 ci V8
Transmission: auto
how can you get the bolts for the top hinge replaced? Do you have to grind away Im assuming and replace? what is the best way because my top hinge has a LOT of slop. The bottom has some slop but i tried changing the bushings and the pin is stuck, really stuck.
Car: 1982 Z-28
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
