can someone help me
Old Jan 7, 2003 | 04:17 PM
pretreat's Avatar
can someone help me
car won't start and i changed the altenator and the battery and still no go but there is a buzzing noise on one of the relays coud that cause the car not to start?:hail:
Old Jan 8, 2003 | 08:07 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Probably not. The buzzing could be your fuel pump priming
Is there spark?
Is the proper amount of fuel getting to the motor?
Is it cranking but no start, or won't it even crank?
Old Jan 8, 2003 | 09:07 AM
pretreat's Avatar
got new battery put in and next day battery was dead went out to look around again then tried to start it the buzzing sound from they relay came on then it stop so i charge battery and car started now the service engin light is on so where do i go from there
Old Jan 8, 2003 | 12:24 PM
MDv6man's Avatar
Car: 1983, 1986
Pull the code by grounding the A and B terminals on the ALDL Connector. Go to the mian page of thirdgen.orgto see how todo this. Let us know what the code is.
Old Jan 8, 2003 | 01:56 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
I know when I first starting coming to the boards I had no idea How to pull codes, so I thought I would post this incase your in the same boat as I was. Go to
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Bottom article, very easy and helpful.
Old Jan 19, 2003 | 08:37 PM
pretreat's Avatar
Ok i found out what its was fuel pump kept runing and drain the battery down , and found out that one of the injectors are plugged which is causing it to run bad, and found the o2 sensor wire connector was hanging off .
Old Jan 19, 2003 | 10:06 PM
Joe_L's Avatar
Car: 1995 Z28
What do you mean by the Fuel pump kept running. If it kept running long enough wouldn't it just flood your car, then pump till it burnt itself out or blew up?
