Wierd Charging Problem. HELP!!!
Old Sep 15, 2003 | 10:47 AM
ybaslo1's Avatar
I have a 91 Z with a v-belt system running only the water pump and Altenator. The altenator is a one-wire set-up. I've had the car running for about 1 month now and I'm on my 4th altenator. When everthing is good I'll have 14 volts at cruise and about 12-12.5 at idle, which is normal, but when they go out, it seems I'm running on battery voltage no matter what RPM I'm at. The wierd thing is that when I disconnect the battery, the guage will shoot to 14 Volts (while the vehicle is running) and I know there's amps cause my fuel pump and electric fans are on. I have the altenator wire running to the starter along with the battery terminal. I am a little suspicious of the battery cables, but my question is, have any of you ever heard of this or have the slightest clue as to what could be going wrong? I load tested the battery and it was good, plus I have no problems starting the thing. Bad wires? Short to ground? Coincedental bad altenators? Any help would be greatly appreciated. Thanks.
Old Sep 15, 2003 | 02:27 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Very weird!
The only thing I can say is: Don't trust the dash voltage gauge, they lie.
Use a Digital Volt Meter(DVM) to measure the voltage at the battery. I also like to measure at the cigarette lighter to read the true voltage when driving.
Old Sep 16, 2003 | 09:24 PM
83_1/2 L69's Avatar
Engine: 305 CC-carb
Also make sure the connections are clean and tight at the starter.
Old Sep 24, 2003 | 11:17 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
Im having the same problem but im using a OEM 91' alternator. Heres my post
My Charging Problem
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
lanceflame44
Sep 25, 2015 12:28 PM
