baer's on a 87gta stk 16" wheel ?
Old Apr 24, 2001 | 11:56 PM
KK87GTA's Avatar
Is anyone running bearclaws on a stock 16" gta wheel. Heard it can't be done, Baer says use the template but that leaves alot to be desired. May just go with ssbc stock stainless crossdrilled rotors.
Pictures would be great.
Kevin k
Old Apr 25, 2001 | 06:58 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It depends on which size rotor you're going with. The 12" (Sport) kit will fit since it's the same size as the 1LE, but the 13" (Track) kit won't fit from what I've heard. I think the only stock 3rd-gen wheels the 13" kit will fit under are the IROC wheels, and even then it's a tight fit.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 25, 2001 | 11:47 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
13" Track won't fit under the cross-lace 16" rims, nor the Iroc rims from what I've seen (there may be exceptions to some of the IROC rims). They WILL fit under the 91-92 Z28 16" rims.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
84 TA NV
Sep 6, 2015 08:02 PM
