injector constant
Car: 1995
Engine: 5.7
injector constant
what does the injector contant do and what are benifits from changing it. also i couldn't find it in my chip but i found BPW contant. is that it. its a 91 rs tbi 8746.
i dont see any benefit in changing it. the benefit is placing in constants, at a correct fiqure, in tuning program. If I recall it is based upon engine size, fuel pressure , and injector size. somewhere is a formula. once you set it forget it. I have a formula somewhere at home. can look up if you need it...
Car: An Ol Buick
Engine: Vsick
Re: injector constant
You need to change it when you change to a different size injector, or you run out of range in the VE table to account for the difference in size.
calculation/equation
BPW Constant = 1461.5 X engine size in Liters / # of cylinders/ injector flow rate in gms /sec
convert injector flow from lbs/hr to gms/sec or 453.6 grams/ lb
now the formula to adjust for FP is the injector size in gms/sec times the square root of (current fuel pressure/GM fuel pressure)
Ok, I'm working with the 1227747 and using the 7747-mine.ecu file I have located:
Minimum BPW Hyst Value
Minimum BPW
Injector bias (added)
Max Async BPW
Min Async BPW
All of these have values way bigger than what the formula above calculates. Is one of these THE injector constant that needs to be changed when swapping injectors or is it hiding somewhere else?
Minimum BPW
Max Async BPW
Min Async BPW
HHmmmm. I use tunercat with a speed density TBI system. my injectors(2) are rated 90 lbs. In TC in constants is a BPW Constant that i am running at 93 however the above formula shows 107 due to my lower FP(9) than 12 lbs(GM specs). i may change it to 107 but that means i need to revisit all my entries for past 60 days. maybe someone else can explain what you are seeing????
Car: check
Engine: check
Transmission: check
well what should it be for 55 pound injectors. and on wednesday im moving to 85lbs.
Thanks,
RBob.
Minimum BPW
Max Async BPW
Min Async BPW
Minimum BPW
Max Async BPW
Min Async BPW
Car: 1995
Engine: 5.7
i am way lost with that formula. i got something way off i think. less than 1
right now my injector constant is at 135. i have a 357 lo5. what should i put it to for the 65 pound injectors.
Car: check
Engine: check
Transmission: check
;* VOL = Vol of 1 Cylinder in liters
;* RATE = Injector flow in gms/sec
357 ci: 357 * 16.39 = 5851 cc's
5.851l / 8 = 0.73140375 l/cyl
65 #/hr: 65 / 3600 * 453.6 = 8.19 gm/s
BPC = 1461.5 * (0.73140375 / 8.19) = 130.5 or 131
The hex address of the BPC in a '747 is $2B4
RBob.
Car: 1995
Engine: 5.7
so the bigger the injectors, the smaller the BPW should be. because on my stock chip (305) its at 134. and the stock caprice chip (350) is 135. so now i should move to 131. that doesn't seem right, unless it has to do wiht me having non stock fuel pressure at 15psi
Car: check
Engine: check
Transmission: check
RBob.
Car: 1995
Engine: 5.7
well i think right now i cant seem to get it richer in some areas. but today im switchin to 65lb from 55. so i wanted to know where i should put it.
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
Old post but I thought using it would be as good as starting a new one.
Question on the math. A 350 with 350 injectors is set at 135 and a 305 with 305 injectors is set at 148. What would it need to be set at if 350 injectors are used on a 305?
I tried the formula and I am wondering if someone could do it to to check my number against.
Car: check
Engine: check
Transmission: check
RBob.
Car: 1983 G20 Chevy
The AE has ended up rich on everything I have tuned so far, when I just change the BPWC and the VE tables. You have to really sit down and find out what the AE and Decel Enleanment need to be. Otherwise my engines have seemed to run a little rough and dirty. Also need to more than likely change values for the IAC pumpshot which gives fuel when the IAC opens, like when your A/C kicks in. Cold start will also give you some troubles occasionally as well.
