How to remove gauge cluster?
Old Dec 14, 2002 | 01:44 PM
Wishmaster's87IROC's Avatar
Engine: 385 HSR.....LS1
I want to remove my gauge cluster to change my bulbs and also when I get the white face gauges, it will be easier to put them on with the cluster removed....How do I take it off? Ive taken the panel and the lense and all the bolts holding it I think but it wont come out....am I missing something?
thanks guys
Old Dec 14, 2002 | 02:57 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Once you have all the crap off and the cluster exposed, look down in the cluster where the 'check engine' bulb is, you'll notice a small thread cutting nut (10mm or something close to that) next to the bulb and another on the other side by the seatbelt light (I think it's that bulb anyways..). You'll also need to disconnect the cable from the back of the speedo (there is a 'clip' to press down on to release the cable head) before the cluster 'glides' right out ( )
Old Dec 14, 2002 | 04:54 PM
Thanks man,,,yeah sorry I did do a search on it and found what I need to do, after I posted the question.....thanks again
Old May 3, 2003 | 11:54 PM
CaysE's Avatar
where exactly is that clip? i couldn't find it last night (though it was dark out)
Old May 4, 2003 | 03:28 AM
88txiroc's Avatar
When you get to the point where the cluster is almost out, but wont pull free, just climb under the dash. Using a long flat screw driver, push on the clip on the very back of the speedo, towards the seat.
I will attach a pic of the clip in a minute.
Old May 4, 2003 | 03:35 AM
88txiroc's Avatar
Ok, here is a pic of the clip. Not the greatest, but it will give you an idea. The part that you need to push on is the tab. It is facing down. HTH
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
