Dash lights cause guages to not work
Old Jul 19, 2001 | 02:40 PM
DaveDog's Avatar
Here is the situation. Headlights, taillights, blinkers all operational. When adjusting dash lights the guages all read about a 20% indication. When rheostat is adjusted so no dash lights, guages work. Also rheostat adjustment also causes dash turn indicator lights to illuminate.
Any ideas?
Old Jul 23, 2001 | 10:46 PM
HIX5000's Avatar
Sounds like you got some bare wires touching. You need to locate them. Happy hunting.
Old Jul 27, 2001 | 08:04 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You have a broken printed circuit trace on the back of your cluster. Same thing happened to mine several years ago..lights off, all worked fine; lights on and the right turn indicator came and stayed on, the oil pressure guage would top-end, and the tach would just 'float'.
Pull the cluster out and carefully check the traces (copper lines) for any broken ones; mine had one where one of the bulb sockets went in. I 'jumped' the broken section with a short length of light guage wire, and have had no problems since.
Hope this helps
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
210+k mile LG4/5-speed
14.891@95.54
My karma ran over my dogma
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
