are there 2 dif kinda clutch forks?
are there 2 differant kind of clutch forks?...because i got one here and it's just barely grabing the throwout bearing...or is the bearing wrong?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
There were 2 different linkages, one mechanical ('82, '82 only) and the hydraulic linkage ('84+). They both use different forks as far as i know. Thats about as much about the forks as i know though.
yea i know it's hydrallic for sure...just when the bearing is on it all the way it's off center with the pressure plate fingers...by the way this is his lil brother..the typin is prolly differant:lala:
Car: 4
Engine: 6
Transmission: 5
That doesn't make any difference. When you put the trans in, it will center the bearing all by itself, regardless of theshape of thespace in the fork. And when that happens, the bearing won't be "all the way" on the fork.
Don't worry about it.
HoosierinWA
Oct 7, 2015 10:15 AM
