Hays Clutch ?'s
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
Hays Clutch ?'s
I'm ordering a clutch today and saw in jegs that you can get the 10.5 or the 11 inch disk. I was wondering if it would fit in there all the rest of the numbers are the same. I just wanted to get a little more surface area than the 10.5. thanks
Car: `86 SS / `87 SS
No; your bellhousing precludes you from using the right flywheel & starter to accomodate it. You could change flywheel & starter and get a Lakewood bell.
Or you could get a clutch for an 85 `vette which is 10.75"
Matthew
Matthew
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
dont get the hays, had it, get the center force d/f do it right the first time
