How do you add up numbers to get compression ratio?
Old Jun 9, 2004 | 12:11 PM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
How do you do this without measuring tools?
Is it Piston + Head CC + Gasket size = ?
Also how do most engine builders degree there cams?
Is there another way to do it? I know pros use degree wheels and some other gauge they use to measure something on the heads at the same time? Valve opening and piston position?
Thanks,
Old Jun 9, 2004 | 01:15 PM
Damon's Avatar
It's cylinder displacement + piston dish (or - for domes) + gasket volume + piston deck height volume + combustion chamber volume
divided by.....
piston dish (or - for domes) + gasket volume + piston deck height volume + combustion chamber volume.
Everything must be in the same units of measure- cubic inches or cubic centimeters (cc's).
Shoot me an email and I'll send you an Excel spreadsheet already set up for calculation compression ratios. Once you see it and play with it some you'll get the hang of it pretty quick. Play with it longer and compression ratios will start to creep into your dreams at night, like they do with me.
Old Jun 9, 2004 | 01:21 PM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
Email sent...
Thanks for the help! :hail:
Old Jun 9, 2004 | 01:38 PM
Damon's Avatar
Right back at ya. Email sent with spreadsheet.
Old Jun 9, 2004 | 01:46 PM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
Got it, thanks!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
apie2546
Sep 5, 2015 07:40 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
