Manual Windows to Power?
Old Nov 10, 2003 | 02:11 AM
Layne's Avatar
Has anyone ever had their manual windows converted to power, and if so, how much did this cost and what type of shop did you go to?
Old Nov 10, 2003 | 07:23 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Our shop charges $350 to convert to power windows using a kit from a company called SPAL, which is a good company for aftermarket power acc. That is an avg price for power windows around my area. Install on our cars by a decent experienced installer should only take about an hour or so. I installed the kit in my camaro in just over an hour. So when you are shopping around, go to a shop that has done plenty of power windows and ask them for a time estimate. Any longer than two hours max for our cars is too long. Our shop is an aftermarket stereo/alarm/tint shop, so you could probably start by checking the stereo/alarm shops in your area first.
Old Nov 11, 2003 | 02:29 AM
Layne's Avatar
Thanks for your advice, definitely appreciate it, it helps knowing where to start!
Old Nov 11, 2003 | 08:53 AM
FastElectrics's Avatar
Car: 89 Camaro RS
I just went to the local pick your part yard.. picked up everything I needed for 40 bucks (canadian).. and put it in.. it was very easy to do.. almost plug & play.. picked up both actuators with motors on em, the rubber boots to go between the door & body, and a good chunk of the wire harness.. did buy new switches though.
Old Nov 11, 2003 | 06:56 PM
ghost's Avatar
Car: 1992 z24
Engine: 3.1
Transmission: 5-speed
my friend did it in his camaro. it took him about 4 hours to do it himself and he never did it before then.
Old Nov 11, 2003 | 07:51 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
this guide should help...
http://www.p71interceptor.com/thirdgen/powerwindows/
i didn't write it, but "Thank You" to whoever did.
Old Nov 13, 2003 | 11:34 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
I went with the SPAL power windows over a "factory" conversion because the aftermarket install is 10Xs easier. I know Redraif also did a similar upgrade, although she may have used a different brand. If you're gonna do the install yourself, check ebay, I got a SPAL kit for like $60-75. The switches, however, will probably run you another $40.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
