Anyone weld a drain fitting on your differential cover?
Old Oct 25, 2002 | 12:51 PM
ebmiller88's Avatar
I'm thinking of welding a fill and drain fitting onto my 9 bolt diff cover. Anyone do this? If so, what's it look like and what did you use?
Thanks.
Ed
Old Oct 25, 2002 | 01:00 PM
ede's Avatar
ede
i have on a few 12 bolts, i used a bung and cap from moroso
Old Oct 25, 2002 | 01:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, to me that sounds like too much work... I usually drill & tap the housing for a 1/8" pipe plug, and use an Allen head plug so it's below the surface of the housing when installed & tightened (no road damage).
Old Oct 25, 2002 | 01:58 PM
ede's Avatar
ede
the morosos fitting is more for a fill or inspection port.
Old Oct 25, 2002 | 03:22 PM
86SCBNJ's Avatar
SLP used to offer one, not sure if they have one for the 9 bolt.
Old Oct 25, 2002 | 05:54 PM
ebmiller88's Avatar
Thanks guys. The Moroso one is the one I want. I found it in Jeg's.
The rubber plug goes in to a big hole in the 9 bolt cover so this one ought to work fine. I don't really want a drain plug, I'd just pull the cover as usual. But for a fill/inspection port, this will work great. Plus, if the drain plug happened to drop out, you'd lose fluid. In this case you'd still have some in there.
Thanks..
Ed
Old Oct 25, 2002 | 07:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wait, so there's no fill hole on the 9 bolt?? How does GM fill them with fluid??
Old Oct 26, 2002 | 12:06 AM
ebmiller88's Avatar
Yes, it's where the rubber plug is. I just don't want to have to keep replacing plugs, tear one, etc. Unlike 10 bolt rearends, there's no fill plug on the side of the pumpkin.
Ed
Old Oct 26, 2002 | 08:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You could always drill & tap one into the side of the housing as well... it's not rocket science. Just put it at the same horizontal level as the stock one. You can buy all the stuff (drill, tap, plug) for less than $10 at the hardware store.
Old Nov 2, 2002 | 01:49 AM
ebmiller88's Avatar
I just welded the Moroso one on the diff cover. It looks kewl. The paint is drying at the moment, so pics to come later...
Ed
Old Nov 3, 2002 | 03:12 PM
ebmiller88's Avatar
Here's the "new" cover. I used the Moroso piece and I think it will be fine.
Attached Thumbnails Anyone weld a drain fitting on your differential cover?-9-bolt-cvr1.jpg
Old Nov 3, 2002 | 03:17 PM
ebmiller88's Avatar
Another view:
Attached Thumbnails Anyone weld a drain fitting on your differential cover?-9-bolt-cvr3.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
I'llrocya
Feb 2, 2016 11:43 PM
