Twin Eaton breathing air
Old Feb 2, 2003 | 06:02 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Thought I'd post a couple pics of the airbox. cheers, Bob
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
side...
Old Feb 2, 2003 | 08:06 PM
DABE's Avatar
simply amazing...
is she done?
Old Feb 2, 2003 | 08:24 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Originally posted by DABE
simply amazing...
is she done?
Thanks. Yes for the most part. Going to do a teardown and clean everything up, grind the welds and repaint. Now just need to make a template for the hood.
Old Feb 2, 2003 | 10:39 PM
LottaBallsCamaro's Avatar
Thats bad ***, where can you buy those kits?
Old Feb 3, 2003 | 01:47 AM
Cole-Trickle's Avatar
That looks so flarkn good,....
If you showed that to somebody that wasn't into cars you could say it's factory and they'd believe you,
keep up the good work
Cheers
Old Feb 3, 2003 | 06:33 AM
'86tranzsheezam's Avatar
OOHHHH BABY! ....Looks great man! Torque monster that should live up to its rather large rockets name....
It don't look like no kit to me....looks like craftsmanship....beautiful work
Old Feb 3, 2003 | 08:39 AM
bhaas's Avatar
Very nice. Hell of a good job. Love that hood. Where did you get those inserts to put in there? Thanks.
Brad...
Old Feb 3, 2003 | 10:16 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Brad...
Thanks.
The inserts are from 87-88 Turbo T-Bird hood. Real nice scoops, have a nice stamped steel mounting bracket and 4 mounting studs. I have some inner sheet bracing to trim and then bend up a "upper" box to seal against the filter.
Oh.. for those that asked. Its not a kit. all home-shop built. BW
Old Feb 3, 2003 | 10:37 AM
BOTLFED's Avatar
Wow SATURN5, that's just amazing.. I love it.. What you're doing now was my initial plan for the Z28, but I fell into some good cheap turbos, and well, you know the rest of the story on that...
Nice job, keep us up to date!
Cheers!
Old Feb 3, 2003 | 10:44 AM
BOTLFED's Avatar
Oh yea, I wanted to ask you if you think it will be ok having no throttle bodies in front of the inlet on the 2 superchargers? This was something I was wondering when I first wanted to do it to my car... (carburated tho)
I guess I can't see any reason why not... Turbos run the same way, so I would assume that it would be ok...
Cheers,
Old Feb 3, 2003 | 07:30 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Cheers,
Well I'm running both blowers ahead of the TB and am using a 1gen DSM blow off valve too bleed off extra air at idle. The $58 code is speed density based, no need to recycle the bleed off. BW
Old Feb 3, 2003 | 08:54 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
you should build that and sell it as a kit for the rest of us
Old Feb 3, 2003 | 11:29 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
ok wait maybe im blind but where does the air acctually enter the engine at ?? im confused
Old Feb 4, 2003 | 01:25 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
That engine bay just gets better and better.
SuperTrans Man,
the air comes in thru the filter box atop the engine. this feeds the superchargers which force the air forward thru the intercoolers and then up into the engine.
Old Feb 4, 2003 | 09:05 AM
Bobalos's Avatar
Hey Bob,
thats one heck of a nice box you got there its comeing together very clean.
BW
Old Feb 4, 2003 | 09:29 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
That it definitly a job well done!!!
Old Feb 4, 2003 | 01:27 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Looks amazing...
Old Feb 7, 2003 | 09:33 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
damn, that thing's gonna be hella fun on the street
Old Feb 7, 2003 | 11:47 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
LMFAO!
Old Feb 7, 2003 | 01:39 PM
Fevre's Avatar
Car: 89 Formula
Re: Twin Eaton breathing air
I kept trying to figure out where your air filters where, now I know. That is a sweet set up! :hail:
Old Feb 7, 2003 | 07:52 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
looks like you went rubber and plastic from the airbox D/side and metal pipe from the airbox on the pass, is this staying this way?
Old Feb 7, 2003 | 11:39 PM
dans82bird's Avatar
Engine: 302
Originally posted by B4Ctom1
LMFAO!
awww c'mon go easy on him... i'm sure you were a noob at one point in time we all learn something new everyday..
lottaballs - it isn't a kit, everything he did is custom... those are the kind of superchargers that come stock on supercharged thunderbirds, bonnevilles, etc...
Old Feb 7, 2003 | 11:54 PM
Hey, **** off ok, its quite obvious that the tubing and such is custom but I thought maybe the mount for it could possibly be purchased. I'm not an idiot.
Old Feb 9, 2003 | 09:43 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Actually its metal and rubber on both sides, in the pic the drivers side was a painted flat black . I made an adapter to convert the Eaton input opening to 3 inch round. The rubber elbows are the MAF ends from a 88 TPI T/A intake hose. I cut off the TB side. Used 3 inch steel bends across the plenum. Then opened to fit the box.
cheers, BW
Old Feb 20, 2003 | 11:57 PM
rooster433's Avatar
Hey if anyones interested i've got one of these exact same blowers for sale, good condition.
I'd easy let it go for $250 or best offer.
Old Feb 21, 2003 | 12:02 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
you should keep it as a spare in case one of them beauties fails, BTW what is the normal max RPM unit operation on a 3.8? what could it be on yours, I know you checked into this Im just wondering about how you sized your pulleys and figured it out.
Old Feb 21, 2003 | 02:40 AM
83 Crossfire TA's Avatar
I know that you didn’t ask me, but eaton doesn’t provide any information on them past 12,000rpm, and the stock applications top out at 10,000-12,000. On my brother’s car with a modified M90 case we’re spinning it right up to around 18,000rpm (2.8:1 pulley ratio, 6400rpm shift point, 6500rpm redline). I think that it will take 20,000, but my brother isn’t willing to try it.
Old Feb 21, 2003 | 07:17 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Not giving up on the LT1 are you???
Old Feb 21, 2003 | 08:19 AM
rooster433's Avatar
nope ...
Last night I bought a M112.
Hehe
I've got a spare intake i've cut in half and having decked down. From ther i'm going to weld a 3/8's 6061 plate to the top of it and mount the blower.
I'm going to run a throttle body on the back of the blower just like a lightning or cobra.
Old Feb 21, 2003 | 09:09 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Oh.... hehe
Old Feb 21, 2003 | 11:38 AM
rooster433's Avatar
yeah i just didn't think a single Eaton M90 was enought for a car that already runs 12.50's
The M112 is supernice, I've heard they are capable of 20psi on lightnings. I really like the internal bypass valve and the demensions are a little better for my application than a M90
I'll post some pictures hopefully.
Old Feb 21, 2003 | 11:48 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
hmmmm twin M112's that would be kinda cooooolll....
Old Feb 21, 2003 | 11:54 AM
rooster433's Avatar
noooooooooooooooo...
just one, two would be a little much!
Its going to be mounted like any other Eaton you see on factory cars.
I've got a intake cut and decked. I've got a spare set of fuel rails to butcher. a spare throttle body with an elbow that bolts to the back of the blower, and spare injectors.
I'm still seeking a cheap FMU (speed density 93 LT1, no 749 swap capabilites because of the all mighty opti spark)
The only thing i've got to do now is have the injector bosses redrilled in my stock manifold to clearance the blower. I need the injectorbosses straight 90 degrees verticle.
Old Feb 21, 2003 | 12:16 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
a LT1 will take a distributor
Old Feb 21, 2003 | 12:24 PM
rooster433's Avatar
not when its still in a 4th gen,
it might but every car i've seen has had to cut into the car to clearance it,
either that or pull the motor out if you want to take the distributor out
Old Feb 21, 2003 | 12:39 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
oh, ok
Old Feb 21, 2003 | 02:06 PM
Well, my brother's 4 door ford will be running 10's with it this year. 1.5-2seconds better in the 1/4 is a long way to go...
I've been looking at some custom rotor mods. If I can convince him to do it I think I could get it to move the same air at about 12000-13000rpm as it is now at 18000, which in theory should allow him to tickel the low 10's turning it at the speed he's turning it now.
Do you have the M112 in your hands? I'd like to see side by side pictures... as far as I can tell from the eaton drawings of them the case should be substantially larger, but with a shorter snout. I'd still rather cut up his passenger side inner fender and strut tower and wedge one of those in.
Old Feb 21, 2003 | 02:11 PM
Ooohhhhhh Yeaaaaaa!
Spinning at 12K you should have enough airflow for about 1000hp
Old Feb 21, 2003 | 02:32 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Little update on the Bu.
Couldn't make the filter box work the way I wanted, so I have switched to K/N cones perched over the inner wheel houses. Adjusted the DS eaton forward an 1/8th to fix an alignment problem and welding a bead on the tubes (for hose retention).
Getting the brakes and chassis finished and checked.
Most of all waiting for warmer weather..
BW
Oh... been kicking of going AWD next.
Old Feb 21, 2003 | 03:09 PM
rooster433's Avatar
Crossfire,
Find eatons website and click on information about the M112,
Its the same width as a M90, shorter (up and down) but a touch longer.
The bad thing is the position of the intake to the blower
The m112 has an internal bypas valve too
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86Firebird86
Dec 26, 2015 07:21 AM
dbrochard
Oct 3, 2015 12:43 PM
edoff13
Sep 11, 2015 03:55 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
