firing order 91 firebird v6
Old Oct 28, 2004 | 08:47 PM
fifefirebird91's Avatar
Car: 91 firebird
Engine: v6 3.1
Transmission: auto
Help. plug wires got taken off dist. cap and now car doesn't run. don't have book and need firing order for 91 firebird v6 3.1 auto??
Old Oct 28, 2004 | 08:57 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Old Oct 28, 2004 | 09:12 PM
Doward's Avatar
5 6
3 4
1 2
(FRONT)
Just like that.
Old Oct 28, 2004 | 10:07 PM
KED85's Avatar
Yep Doward correct.
#1 is front passenger side.
Go to cap, it's 7:00 position.
Skip a spot, next is #3, skip a spot, next is #5.
Then back to front of distb cap, starting with, as also said, next, #2 and so on.
IF ya really feel not sure on distb cap, remove the #1 plug, bring that piston to TDC, look at rotor position.
Old Oct 28, 2004 | 10:12 PM
Car: 91 firebird
Engine: v6 3.1
Transmission: auto
plug order on distributor cap itself??
The wires are on the plugs themselves, but taken off of the distributor cap. I think the order is 1-2-3-4-5-6-counterclockwise, but which one is #1?
Old Oct 28, 2004 | 10:19 PM
KED85's Avatar
REREAD MY REPLY!
I said it's the 7:00 position on the cap.
To double check again pull #1 plug, bring engine to TDC & see positon of rotor. It'll be at 7:00 position. Drop on cap & there ya go.
Clockwise is rotation of rotor.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
justin57
Aug 20, 2015 07:05 PM
TheExaminer
Aug 19, 2015 10:07 PM
