Flames out of Holley 4160
Old Sep 29, 2004 | 09:24 PM
VanBC's Avatar
Car: 85 Z28 - IROC
Engine: 5.7L 350
Transmission: Auto for now...
Hi guys,
Need some input here.
I've got a 350, Holley 4bbl carb (4160) stock jetting, RV cam.
I've got a really wierd condition when I push hard on the gas. It sometimes just shuts off if I go full throttle to the floor.
If I'm cruising around and not using the secondaries it's fine.
I took the air cleaner off and manually, quickly revved it from 0-100% and let off, and a flame birst out of the carb.
I have the idle screws at 1 1/2 turns out, the accel. pump to stock spec., the floats are on the leaner side, and the intake leak was fixed.
Plugs are black and sooty. so I'm sure it's rich.
Any suggestions why this is happening?? How to cure it? Is it a timing issue?
Thanks guys.
Old Sep 29, 2004 | 09:27 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
When I first got mine together it did something similar. Turned out I had #5 and #7 plug wires swapped. I felt like an idiot.
Old Sep 29, 2004 | 09:38 PM
VanBC's Avatar
Car: 85 Z28 - IROC
Engine: 5.7L 350
Hmm...
I should check my plug order.
But did it run with the plugs reversed?
Old Sep 30, 2004 | 07:05 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
A little rough, but it ran ok. It was my first carbed motor so I didn't know what to expect. As long as I didn't mash to throttle it would keep running. If I was too fast it would shoot flames out of the carb and stall.
Old Sep 30, 2004 | 04:51 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
check your timing
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
2012sergen11
Oct 13, 2015 07:38 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
