New REAR and Wheels, Should They Fit?
Old May 12, 2004 | 03:13 PM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
Hey i will be installing a rear end from a 95 Pontiac into my 89 RS. It comes with 2 stock TA Rims from 95. Will my tires still stick out using the 4th gen rims back there? Will i have any clearance issues on the inner fender well? I have read a lot of posts on here including the tech article on swapping rears, but no one comes out and says if i run the 4th gen rear on 4th gen rims, if there will be any clearance issues on my 3rd gen camaro that has been lowered using the SPORTLINE Lowering springs:HELP:
John
Old May 12, 2004 | 03:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They should fit. They should come out to within ½" or so of your existing wheels on both the inside and outside, depending on how wide your current ones and the other ones are.
Old May 12, 2004 | 03:56 PM
Car: 89 RS
is anyone running both the 4th gen rear AND rims on a third gen?
Old May 13, 2004 | 07:38 AM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
flyinlow is
Old May 13, 2004 | 11:47 AM
Car: 89 RS
Originally posted by camaro05
flyinlow is
I can't seem to find that exact username, how do i get ahold of this gent to through him a few questions???
Old May 13, 2004 | 11:52 AM
camaro05's Avatar
Car: 91 Z28
here is his exact name FLYNLOW92rs or you can look for him in the detailing and appearance doard. his car is all over it.
Old May 13, 2004 | 03:42 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
They'll fit just fine; it's been done many times and is required. I installed a 95Z rear end in my car and have aftermarket wheels with a fourth generation offset. Like a glove! With the fourthgen rear, your thirdgen wheels would stick out of the fenderwell about 2" on each side IIRC.
Old May 14, 2004 | 08:33 AM
Car: 89 RS
Originally posted by Frains90RS
They'll fit just fine; it's been done many times and is required. I installed a 95Z rear end in my car and have aftermarket wheels with a fourth generation offset. Like a glove! Without the fourthgen wheels, your thirdgen wheels would stick out of the fenderwell about 2" on each side IIRC.
Thank you bud, Looks awesome. So are you running spacers in the front then? Also, what size tire are you running in the rear.
john
Old May 14, 2004 | 11:28 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
john
275/40 tires all the way around and Im using 2.25" spacers in the front because my wheels have a high offset (+56mm).
-Efrain.
Old May 14, 2004 | 11:48 AM
Car: 89 RS
-Efrain.
that is a mights large offset, are you spaced in the rear too?
I would like to be able to run without spacers on mine, one less week link.
john
Old May 15, 2004 | 02:47 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
john
No spacers in the back. I was surprised about the fit too.
And yes Ed Emerson is the guy on ebay in Torrance. Sounds like you are getting a deal though for under $200.
Good luck,
-Efrain.
Old May 15, 2004 | 05:18 PM
Car: 89 RS
hopefully the good deal goes through.... I got my fingers and toes crossed.
john
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
