gas gauge allways read full
Old Aug 21, 2002 | 08:36 PM
rssman80's Avatar
My gas gauge read full at all times. Has anyone had this happen to them, and if so, whats the reason why its doing this???
thanks in advance
Old Aug 21, 2002 | 09:11 PM
2vmodular's Avatar
gas guage will read a little past full if there is a break in the wiring between the sender in the tank and the guage.
senders in the tank have been known to fail too.
Old Aug 23, 2002 | 12:26 PM
silver89Rs's Avatar
this has hapened to me twice since ive had my car. both timesit was caused by the needle getting stuck behind the trim around the gauges. i just took of the clear plastic cover and unstuck the needle
Old May 17, 2003 | 10:12 PM
rubber_lee's Avatar
stuck needle
My temp needle was stuck and annoyed me for the longest time. I finally took some clear plastic tubing and cut a very small piece and stuck right in there. The needle will hit and bounce right back to normal like it should. The little tube is not noticeable at all and works great.
Old Jun 18, 2003 | 08:34 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
my gas gauge is stuck straight up aswell, and its not caught. is it an in take problem? or is it a wire thats known to break?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
Armored91Camaro
DIY PROM
Aug 12, 2015 09:41 AM
