Getting headliner redone?
Old Aug 17, 2002 | 08:12 PM
burnouts4ever's Avatar
how much does it cost aproximately to get a headliner redone, i dont have t-tops
Old Aug 17, 2002 | 08:45 PM
Z28DJP1987's Avatar
By a Pro about $150.00
Old Aug 17, 2002 | 10:45 PM
6cycbird86's Avatar
Car: 88 GTA
Engine: 5.0
Transmission: Manual
Axle/Gears: 3.45
the guy who owned my car before me had it done by a pro and it was 320$ approx. - good thing he did it cause i woulda resorted to a staple gun
Old Aug 17, 2002 | 10:52 PM
LT1guy's Avatar
Car: 1987 Trans Am
$100-150 if the board is good (reusable)...if not, $300+
Old Aug 18, 2002 | 01:22 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
$30 max, if you're willing to do it yourself. 2 sq yards of headliner fabric from Joann's Fabrics. $8 + tax for the 3M Interior Trim Adhesive (in a white can w/ red lettering). A tire brush to get off all the disinterated foam.
AHH Here's a message I posted in the So. California board
New headliner fabric??? Joann's fabrics, $11.99 per square yard, for a Hard top, I used 2 yards and had enough left over to redo the visors. (Felt kinda weird walkin in a store that mostly girls go to, but you're a girl, so you won't have that problem) TIP: Take one sunvisor with you to get the closest color match, and maybe buy enough to redo the sail panels so they match.
Take out your dome lamp and unscrew your coat hooks above your speakers and remove the visors.
Slide your A-Pillar covers forward, and then pull them towards the inside of the car.
Unclip the seatbelt cover things, drop the headliner.
Remove all the old Headliner, and brush off the disintegrated foam.
Lay on new headliner fabric, and cut the holes to match.
Spray 3M Interior Adhesive (NOT SUPER 77, that doesn't hold up in the heat of so cal) all over.
Installation is the reverse of removal. (I ALWAYS WANTED TO SAY THAT!)
Old Aug 18, 2002 | 11:27 AM
LT1guy's Avatar
Car: 1987 Trans Am
That's pretty much what Redraif and I did on her car...fortunately the last time the headliner was replaced it got a new fiberglass board, too.
Old Aug 18, 2002 | 11:44 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
t top headliners are a pain in the *** to recover. Doing a hard top would be gravy.
:hail:IROC-Z
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
birdman_29
Jan 7, 2017 08:24 AM
Veaceonee
Sep 29, 2016 08:15 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
blackbmagic
Sep 8, 2015 10:36 PM
