wheres the proper place to jack up your car?
Old Feb 21, 2001 | 12:06 AM
matthew's Avatar
yesterday morning I was greated with a little surprise when I went out to my car. My right rear tire had a flat. No biggy I thought. I'll just take it off and bring it in to NAPA to have it fixed. Well it didn't go so well. My first problem was that I couldn't get my rear axle jacked up. My rear had sank so much that I couldn't get my floor jack underneath my muffler to lift on the differential. So I tried closer to the tire, but the sway bar was in the way. Finally, I got mad and lifted on the sway bar bushing enough to get my tire off and then I put a bottle jack right behind the brake. there has got to be a better place to lift your axle. Where is it? Also, while I'm at it, what should the air pressure be in the tires? It is at 33 psi all around right now. Before I checked it, there was an 8 psi difference between the tires.
thanks for the help
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Old Feb 21, 2001 | 10:07 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've always been able to slide that spare-tire-jack under the pad "in front of" the rear control arm, on the side I've had the flat on. That doesn't raise the axle per-say; it raises the body of the car, and when you raise the body enough, the axle lifts up.
Old Feb 24, 2001 | 04:59 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
The tire pressures should be listed on the side of the door (where the latch is) or on the body where the door latches. Usually 32psi is good. There's jackpoints between the tires on the sides of the car. One's right behind the front wheel, and one's right in front of the rear wheel. If you have an owners manual, it describes it a hell of a lot better in there. Hope any of that helps.
Old Feb 24, 2001 | 05:39 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Yes 32 psi cold is the factory spec. I was running 36 psi cold 2 years ago and really wore out my tires fast. I usually put a few more psi in the front, and a few less in the rear. If you can't measure it cold just add 4 psi - i.e. 32psi cold = (appx) 36psi hot.
"We lost Dale. This isn't fun anymore"
R.I.P. #3
"The inevitability of death serves as the most clear evidence that to truly live, one must constantly court death, flaunt death, smack death around, and basically grab death by the throat and dare it to come too soon."
- Me
customblackbird
Aug 15, 2021 10:16 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
B_Dubya
Aug 26, 2015 05:09 PM
mizz0313
Aug 12, 2015 06:45 AM
Amillionoh7
Aug 7, 2015 01:24 PM
