32mm IROC to 36mm WS6 Swap
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Is this a simple bolt up swap with new bushings and end links, one in and one out, or are there other things to consider?
JamesC
JamesC
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
That simple. And you can reuse your orig endlinks.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
Justin,
Tradition wisdom claims that beyond the sway bar bushings, mixing poly with rubber is a bad idea (i.e. going with poly sway bar bushing and endlinks, but leaving the control arm bushings rubber). Any thoughts?
JamesC
JamesC
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Definitely replace the endlinks as well. Finding 36mm bushings is difficult as only a few companies make them(and energy suspension isn't one of them). You'll definitely like the difference with the WS6 bar.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
<font face="Verdana, Arial" size="2">Originally posted by JamesC:
Justin,
JamesC
</font>
Justin,
JamesC
</font>
If your going with poly, make sure you keep it all well lubed with marine grease otherwize you will end up with binding problems.
-Justin-
[This message has been edited by Justins86bird (edited February 18, 2001).]
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Energy Suspension has them. I think Global West does too.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Strange. My 85 IROC has rubber sway bar bushings but does have red endlink bushing. I always imagined that someone somewhere sometimes swapped the rubber out.
JamesC
JamesC
My car came from the factory with rubber sway bar bushings and red endlinks.
-Justin-
-Justin-
If these are stock poly, what gives?
JamesC
JamesC
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The only people I have have found to make 36mm poly bushings is Guldstrand. Kind of expensive though.
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Yes I believe the red endlinks are stock poly. I always thought that the 1 previous owner had installed them. But everything on the vehicle was bone stock, so that would be a strange/unique single upgrade. Then I saw them on other camaros (at least Z28/IROC) and realized they had come that way.
James
1985 Z-28 305 TPI
221,000+ mi., Original Eng.
James
1985 Z-28 305 TPI
ambainb
Apr 25, 2016 09:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
