1987 Firebird Formula Question
Hi, I ran into low mile 1987 Firebird Formula. It is a carbureted model with the 305 v8. I was curious as to if this model has only the mechanical fuel pump. I am looking to avoid any car that has the electric fuel pump in the tank as when it goes out it creates a huge problem. Did the 1987 carbureted cars have only a mechanical fuel pump or did they also have an electric one in the tank as well. I remember reading that they put both electrical and mechanical fuel pumps in some models.
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: 1987 Firebird Formula Question
I believe there is a low pressure pump in the tank. The only years that had nothing in the tank were LG4 82-84 cars.
some early HO cars had no in tank pump but I believe most of them had it.
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
To prevent fuel vapor lock, the LG4 had both mechanical and electric fuel pump in ‘87.
