Fuel pump
Old Dec 9, 2014 | 08:57 AM
sitheoriginal's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 5.0 TBI
Transmission: Stock
Axle/Gears: Stock
Fuel pump
I'm having trouble with my firebird not getting gas from the tank to the carb. The engine will run if you pour gas into the carb. I've been reading repair manuals and for what i can understand there are both a fuel pump in the tank and a fuel pump on the motor that is ran by the cam. Is this right?
Old Dec 10, 2014 | 06:23 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: Fuel pump
Depends on the year of the car also make sure the push rod for the mechancial fuel pump is installed if its not then ur not gonna pump fuel up to the carb
Old Dec 10, 2014 | 08:32 AM
Engine: 5.0 TBI
Transmission: Stock
Axle/Gears: Stock
Re: Fuel pump
1987 firebird formula 5.0 TBI
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
