stalls with A/C on
Old Aug 28, 2002 | 02:33 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
stalls with A/C on
I finally got the programmer and tunercat software. I burned a new chip and my car runs so much better. It starts, idles on its own, and goes into gear cold with no problems. However, when i turn on the A/C at idle the engine will bog down and die. Turn it off and it is fine. Once it warmed up I test drove around the block and tried the A/C. Blows cold while driving but at a stop sign it died again. I did try the raise the "add to idle A/C on" constant, but that seems to do nothing for it. Anyone have any ideas? Let me know.
Old Aug 28, 2002 | 05:03 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Try a little more fuel at idle, and maybe taking a little timing out.
When the trottle blade opening is just sooo small, the extra load just will force a stall.
You also want to make sure the min idle speed is set just right.
Or just delete the A/C......
Real cars use HP for other matters..
Old Aug 28, 2002 | 05:31 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Thanks for the reply.
Whats the best way to set the min. idle setting?
Also S. FLorida is pretty hot and humid all year long and I don't like to sweat while driving around town.
Old Aug 28, 2002 | 06:32 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I turn the key on with the ALDL jumped A-B. Then wait a minute and unplug the IAC. Key off, unjump ALDL. Disconnect EST as applicable (Distributor cars need to unpleug it).
Start engine, set idle speed just so the engine will idle half decent, ie smooth, and steady, but no higher then that.
Reset TPS as needed.
Then try to get a good idle with 0 IAC counts.
You might try adding some IAC counts AC on to get to a new block for timing, and fuel, that would proably be a good way to go.
If the car is KEWL enough you won't sweat.....
Just teasin ya.
Old Aug 29, 2002 | 06:23 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Thanks for the info. I'll give her a try next day off.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
