in line fuel pump for Lt1 swap
Old Jun 29, 2003 | 11:19 AM
windowlicker's Avatar
I am considering using an inline fuel pump for my Lt1 swap (94 vette 4l60e into a 89 v6) rather than go through all the hassle of dropping the tank. Has anyone done this before?
Zepher: I know you are doing something similar, do you actually have it hooked up yet? I'm thinking of using the Aeromotive A1000 or similar pump.
Old Jun 30, 2003 | 08:05 AM
bluepastu's Avatar
Car: 87 vert
I used the stock fuel pump(intank) on my 87. It's been 4 mnths and not a problem yet.
Old Jun 30, 2003 | 08:33 AM
mat89RS's Avatar
you can use your stock pump, check the pressure with a pressure gauge.... if it's over 45-48 psi, you should be alright.
Old Jul 1, 2003 | 03:39 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have mine hooked up and it worked great when I was running the TPI setup.
I had a carbed car and didn't want to drop the tank so I went with an inline Holley Universal 230lph 45psi pump.
Old Jul 2, 2003 | 06:52 PM
thanks for the great pics
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
