1LE vs FE2 vs WS6
Old Nov 15, 2002 | 11:55 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
1LE vs FE2 vs WS6
i have an 89 IROC, it has the crappy f41 suspension package, what factory third gen springs are the best the 1LE springs, the FE2 IROC springs or the WS6 firebird springs?
Old Nov 15, 2002 | 12:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Doesn't really matter any more, they're all worn out, all of them, they're garbage, they're over 10 years old now. No sense in fooling around with a bunch of used-up stock springs if you're trying to upgrade something.
If you want a great set of springs with stock ride height, here's what you should do. Look up in a Moog paper catalog for the springs for some one of these cars, doesn't matter which one. Go to the back of the catalog and look in the buyer's guide section where they're all sorted and listed by their specs. Find the section for springs of this design (straight one end, ground tapered the other), then look down the list of outer siameters until you find the F car spring you looked up. Now pick out the one part number that has the highest spring rate in the whole group, with the installed height (nothing to do directly with ride height) that most closely natches the one yo looked up. There's one part # you'll come up with that way, wish I could remember it but I can't. That's what I have in my car, it's excellent. NAPA has the same parts (Moog) under their own part #s, you could go there and do the same thing. Then get a set of Moog CC635s for the rear.
Old Nov 15, 2002 | 12:21 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
id be buying the springs new from GM
Old Nov 15, 2002 | 01:07 PM
MdFormula350's Avatar
i want to say the 1LE springs, not sure though but i think the iroc-z springs are the same as the ws6 springs..
Old Nov 15, 2002 | 04:41 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
i heard that the WS6 has stiffer front springs then the IROC but softer rear springs then the IROC.
oh well im thinkin the 1LE springs would be the best choice
Old Nov 15, 2002 | 06:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Waste of money, pointless.... they just buy the replacement ones from TRW or Moog or whatever and charge that wonderful cover charge for their label... they're not the same as what came in cars.
There's categories of parts: things that you have to buy at the dealer, things that you can buy at the dealer or elsewhere as you choose, things that are stupid to buy at the dealer, and things you can't buy at the dealer at all. Springs are in category #3.
Old Nov 15, 2002 | 08:35 PM
iroc22's Avatar
Well to answer the original question, the 1LE shocks and struts are a bit stiffer and a different part number than the WS6/FE2 equivalents. If you're going for performance, 1LE is the way to go.
Old Nov 15, 2002 | 11:28 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
sweet, 1LE.NET has all the 1LE option part numbers, i can get the stuff for cheap from a guy that doesnt live to far from me
Old Nov 16, 2002 | 06:14 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
how good of a hook-up could it be?
Old Apr 27, 2003 | 05:46 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
89 IROCs came with F41??? My 88 TBI--15" wheel IROC has FE2
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
dbrochard
Sep 7, 2015 09:41 AM
