map - volts to kpa
Old Mar 24, 2002 | 05:05 PM
Z_Ghost's Avatar
map - volts to kpa
Has anyone come up with a good conversion to this, I found were Craig posted this ?
KPA = 18.23 - Volts + 10.9
I am using EASY and Tune Cat.
Old Mar 25, 2002 | 07:51 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
Hey Z_Ghost,
How you been doing, We met at Ennis drag raceing a while back.
I have the Blown White Convertable, send me an E-Mail, I've been
using Tunercat for a more than a year.
Old Mar 25, 2002 | 08:03 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Hook up your scanner and turn the key before you start tuning to see what the Map volts are. Mine is around 4.90 volts most of the time. Then just divide the volts at the rpm you want to work with, by the 4.90. IE 1.80 volts divided by 4.90 volts = 0.37, 37 KPA.
Old Mar 26, 2002 | 05:11 AM
Z_Ghost's Avatar
Thanks mike I will do that.
Hi Louis, I will.
Old Mar 26, 2002 | 01:31 PM
Vader's Avatar
In a perfect world, it should be something like this:
Old Mar 27, 2002 | 04:16 AM
Z_Ghost's Avatar
WOW Vader replyed to my post.
Vader you know from my notes that is close to what I was reading.
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
