Making my own SFCs with "new" design..input please.
Old Feb 3, 2001 | 10:30 PM
Jester's Avatar
New as far as I know anyway. What I'm going to do is use 2 lengths of square tubing per side. I havn't decided if I wanna use 1.25" or 1.5".
They'll be welded together, both weld to the same place on the rear subframe. They'll go up the body, stiched on to it every few inches. But, when it gets to the front subframe one will split off in a Y and they'll weld in at 2 different spots. I might even tack on another support leg, making a K shape. I'll make a straight piece up to the front of the subframe near the tranny bellhousing, while the offshoot of the Y will go to the very rear of the front subframe.
Opinions?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Feb 4, 2001 | 05:09 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Just copy everybody elses designs. The "K" sounds like a little too much. The "Y" design is probably the best. This is what I'm gonna do too. But I'll just copy the aftermarket.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 4, 2001 | 09:16 AM
ede's Avatar
ede
use 2x1.5x.125 and maybe 1x2x.087 for any secondary bracing
ICON Motorsports
1st & 3rd
kairles
Oct 26, 2015 09:13 PM
cougar20th
Aug 27, 2015 08:04 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
