Distributor selection ?'s
Old Jul 11, 2002 | 12:07 PM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
I'm currently modifying my engine and I need some advice.
I have an '87 LG4 and I'm junkin everything on the top end of my engine and putting in the following: Iron vortec heads, Edelbrock preformer RPM intake,700 CFM carter carb,heddman shorty headers with matching Y-pipe,Hooker cat back, Self aligning roller rockers, and so on.
I need help picking an ignition setup and money isn't a problem,
First I need to find a distributor, and it has to bypass all ECM or engine computer crap so what distributor typre should I get,Vaccum advance or mechanical.
I'll also consider an electronic ignition.
My car will also be lacking all emmisions equipment.
I need reliability and power from this sucker so please any input is much welcomed.
Old Jul 11, 2002 | 12:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Distributors without computerized advance all have mechanical advance to adjust the timing according to RPM. Any car driven on the street will also benefit from vacuum advance, which adds more advance when the throttle is open and the engine is lightly loaded (i.e. cruising), for gas mileage. It's good for 10% or more better fuel mileage.
My recommendation is Performance Distributors in Memphis. That's what I have, works great.
Old Jul 11, 2002 | 12:35 PM
Car: '86 Trans Am
Thanks.
But is that a service,store,or manufacturer.
I'm looking to do mail order and I would like to hear peole's input on what my selection should be.
Old Jul 11, 2002 | 01:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
mfr
901 area code; call dirctory assistance
they do mail order
Old Jul 11, 2002 | 01:51 PM
Car: '86 Trans Am
cool.
Anyone else?
Old Jul 11, 2002 | 02:34 PM
ATOMonkey's Avatar
Order an HEI from Jegs or summit or where ever. Just get a good one. Should be less than or right around 200 bucks. Comes with cap rotor coil and only takes one wire to power it and you can tap into the existing harness for a tach signal. They come with vac idle advance and work really well.
Old Jul 11, 2002 | 03:07 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
MSD ready to Run (doesn't require any ign box, just a coil)
PN#8360, $246.95 at Summit Racing Equipment.
http://store.summitracing.com/
Chevrolet: 262-454, Ready-to-Run Pro-Billet distributor
MSD Says:
The Pro-Billet Ready-to-Run distributor is the perfect upgrade for outdated points distributors or bulky HEI's. Just install the distributor, connect three wires and you are cruising. A powerful ignition amplifier is built into the housing. The increased output of the amplifier outperforms stock ignitions and will smooth out the engine's idle, improve starting, and provide a much higher rpm range. The distributor also features MSD's adjustable mechanical advance so you can custom tailor an ignition curve to match your engines needs. A vacuum advance canister helps improve fuel economy. Supplied with a cap, rotor, iron distributor gear, and vacuum advance.
-Rich-
Old Jul 12, 2002 | 11:01 AM
Car: '86 Trans Am
question are those three wires cause I don't wanna use any factory wiring.
I'm bypassing all of that cr@p.
Old Jul 12, 2002 | 11:41 AM
Car: 92 Camaro RS
The three wires are: Ignition Hot, Ground and the Negative Terminal of the Coil.
-Rich-
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Damon
Sep 26, 2015 04:29 PM
