T56 swap into two piece rear main seal engine block
Old May 8, 2004 | 11:46 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
I need some help. I want to build a new engine or probably buy one already assembled for a twin turbo application and would like to have this next specs on my new engine; 4 bolt mains, roller cam and one piece rear main seal. I already have a T56 and I would like to know if the T56 will fit right into a two piece rear main seal engine block. If not what are the parts necessary to make this kind of swap. 4 bolt main/roller cam/one piece rear main seal blocks are kind of rare and difficult to find, or perhaps I am looking in the wrong places. I would want to build a Dart little M block with the T56, but I dont know if this is possible. In resume I would like to know if its possible to swap a T56 into a two piece rear main seal engine block, and if it's, what are the parts needed.
Any help will be greatly appreciated
Old May 8, 2004 | 12:07 PM
Flyte risk's Avatar
Car: 85 IROC
Engine: tree-oh-five
Transmission: 700, but the T-56 is laying on the floor
If you go with a 2pc rear main all you have to change is the flywheel.
I don't know the part # right off but CenterForce makes the one you need as I'm sure a few others do also.
Old May 8, 2004 | 12:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need a Centerforce 700107 flywheel. The stock T-56 bell housing, hydraulics, shifter, etc. will all work. You'll need to adapt the crossmember somehow. I'd suggest an aftermarket torque arm specifically designed for the swap, such as the Spohn one.
Attached Thumbnails T56 swap into two piece rear main seal engine block-centerforce-700107-flywheel.jpg
Old May 8, 2004 | 01:06 PM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
T56/Two bolt main block
Ok,
I already had this tranny previously installed in a 87 GTA with 350 one piece rear main seal I use to have, it was running great.
So what you guys are telling me is that the current T56 93-97 flywheel that I have and used before in the 87 GTA, wont work with the new two piece rear main seal engine block that I want to build, and that I have to change that flywheel for a Centerforce 700107 flywheel or simmilar and that new flywheel will fit this two piece rear main seal engine block with the T56?
Sorry, but I just want to be sure I understand.
Old May 8, 2004 | 02:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like you've got it.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
