Pontiac 400 In A 87 Firebird
Old Mar 23, 2004 | 08:59 AM
SWATFIREBIRD's Avatar
Car: 87 FIREBIRD
I HAVE A 87 FIREBIRD WITH A 305 WHICH IS RUNNIG HIGH 14'S ON STREET TIRES. I HAVE A 400 PONTIAC ENGINE WITH TRANS
SO, I WAS THINKING TO SWAP THE 305 FOR THE 400. HAS ANYONE DONE THIS BEFORE AND WOULD IT BE A HAZARD?
Old Mar 23, 2004 | 09:31 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I believe that there is a kit to do that, sold by Indian Adventures (I think they're in Mass?, somewhere in the North East). I have seen them around before, and they run very strong (depending on how well you set up your engine) so I know someone makes headers too. It will NOT be the cheap way to go, the cheap route would just be to drop in a 350.
It will depend on the year of your Poncho engine, they changed engine mounts on the blocks somewhere around 1970.
Old Mar 23, 2004 | 10:16 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
there is also a kit to adapt the older blocks to the newer motor mounts. Some blocks had both old & new bosses tapped.
a search should answer most of your questions, as a couple peeps have already done this/are working it already.
Old Mar 23, 2004 | 10:23 AM
Car: 87 FIREBIRD
THE ENGINE IS FROM A 78 TA THE GUY THAT SOLD IT SAID IT WAS REBUILT.
Old Mar 23, 2004 | 10:26 AM
Car: 87 FIREBIRD
I RARELY DRIVE MY CAR ON THE STREET SO, I WILL USED IT MOSTLY ON THE TRACK THATS WHY I THINK THAT THE 400 WILL GIVE ME MORE THAN THE 350.
Old Mar 23, 2004 | 10:30 AM
Engine: 5.7 / 7.4
block mounts will be a non-issue then
EDIT: what heads are on it? 6X-4 or -8??? gotta love that 8.0~8.5-1 stock compression
Old Mar 23, 2004 | 08:28 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
my bro's '77 TA ran 13.8@101 MPH with a STOCK 400 with 8.5:1 compression and stock under .400 lift cam....just headers...all that in a 3800 LB car.....the Poncho 400 is a create engine and I plan on a similar swap in the future for a track car.
A mild 400 can make easy 400+hp and propel a 3rd gen into the 11's relatively easily.
Indian Adventures sells motor mount adapters and headers for 3rd gen 'birds...the headers are a little pricey...but hey what can you do.
My suggestion is to ahead and do the swap....I plan on starting a project like that in a year or two.
jhawkeye
May 25, 2022 06:33 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
