Brembo Brakes
Old Oct 20, 2003 | 08:55 AM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
Brembo Brakes
My comment about wilwoods not looking like the real thing was not a slam I was just stateing a fact. The wilwoods do look good and I even contemplated using the GN6 caliper for my brake conversion but I felt that the wilwood would not fill my needs for brakes. So I am running brembos. I have driven cars setup with the wilwoods (mustang), my dad has a ZR1 and I have driven Z06's and LS1 SS. The brakes on all of these cars were far superior to the stock 3rd gen brakes (non 1le). I have thought of selling my brakes as a kit but it would cost $2000+ I would be in direct competion with Steve and Alloy.
Old Oct 20, 2003 | 10:35 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
well, since you arnt selling it....
details please....
what are you running for the rotor? 1 piece or 2? where did you get it?
what model caliper? where did you get it?
did you make your own hub by machining a stock rotor or what?
Old Oct 20, 2003 | 03:39 PM
355SS's Avatar
Car: 90 Camaro
https://www.thirdgen.org/techbb2/sho...hlight=porsche
Old Oct 20, 2003 | 04:09 PM
Kandied91z's Avatar
i like them, it's different which is good.
Old Oct 20, 2003 | 10:31 PM
ebmiller88's Avatar
Some guys make cars go fast...he makes cars stop fast. Geez, what a setup.
Ed
Old Oct 20, 2003 | 10:44 PM
CrazyHawaiian's Avatar
Car: too many ...
I'm interested in your rear setup. Are you selling that as a package?
Old Oct 20, 2003 | 11:02 PM
355SS's Avatar
Car: 90 Camaro
The rear brakes are overkill for most front setups that I have seen. I wouldn't run them unless you have the same fronts as me or are running the Porsche gt2 (6 piston) or the Baer extreme+. As for selling the fronts or rears as kits I would have to sit down with my dad and talk it over. I am an engineer and he owns a machine shop so I design the parts and he turns them into reality. Next you are going to want to buy my rack & pinion steering system. I would also have to look into the liability in selling the parts. As far as rear brakes go the stock pbr set up is quite good when proportioned correctly. I have met quite a few 4th gen owners that are running the similar front brakes as me and are still running the factory rears with better pads and a proportioning valve.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
