3RD Brake light lense
COTM Editor
I need a 3rd brake light lense for my 91 Z28 convertible. Not seeing them listed anywhere.
Any leads or suggestions here guys?
COTM Editor
Re: 3RD Brake light lense
That is what I thought, but I haven't been able to do more than hold up my empty housing to my buddies light and see that they are close. Appreciate it!
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
I used a center brake light lens from an IROC 3-piece spoiler, and it fits pretty good. The problem is the brackets are not the same. So I epoxied in a couple of plastic tabs and drilled mounting holes in them, and screwed in the lens. Almost perfect fit, except the bottom edge of the lens sticks out slightly from the face of the spoiler (approx. 1/8") Otherwise, it looks factory fresh.
COTM Editor
Hi there,
Hi there,
Axle/Gears: 3.45, 3.27, 3.27
You were correct with your original information. There is no difference between the 88 through 92 convertible HMSL and the 87 through 90 Camaro coupe.
Lon
Lon
On Probation
On my old brake light housing, the housing was longer than the coupe's housing. The mounting tabs in the spoiler were quite a bit farther back. So I took a couple pieces of plastic and some JB Weld and made tabs closer to the opening.
I thought they were all the same, but it did not work on my spoiler.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
I thought I read elsewhere here that some factory ragtops used
a modified Ford/Lincoln piece.
There were pics clearly showing Ford script on it........................
Here:
https://www.thirdgen.org/forums/conv...-vert-3rd.html
Here:
Here:
Here:
