Heater Blower broken?
Old Dec 7, 2003 | 07:23 AM
german's Avatar
Car: 91`GTA
Engine: 305cui
Transmission: Borg Warner T5
Today my blower from the heater doesn`t work anymore. I can turn the heater **** on Low/med/high nothing happens. There still comes a little airflow from the vents when I drive but that is not much. Where can I start to search to find the problem?
Old Dec 7, 2003 | 07:44 AM
ede's Avatar
ede
fuse box
Old Dec 7, 2003 | 08:34 AM
german's Avatar
Car: 91`GTA
Engine: 305cui
I already check the fuses- no damage. Are there fuses under the hood to? I just check the fuses under the dashboard.
Old Dec 7, 2003 | 08:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Check the purple wire that plugs into it, see if there is 12V on it when you turn it on. If there is, then the motor is bad. If not, it's a wiring problem. As said before, check the A/C fuse under the dash first. If it's good, you have a wiring problem. No fuses under the hood.
The single most likely point of failure is the wire that supplies power to the A/C control head. If you remove the control head from the dash, you will find (among a few other wires) a brown wire connected to the "mode" switch. If you follow that brown wire as it leads away from the switch, about a foot from the switch, you will come to a connector of extremely stupid design that is probably burnt to ashes. Replace this connector with a set of HEAVY DUTY slide terminals.
Old Dec 7, 2003 | 11:36 AM
german's Avatar
Car: 91`GTA
Engine: 305cui
I now checked the blower motor- works perfect. Then I checked the plug from the switch. There are 5 wires and there is no power. I check the fuse panel and there is 12V. So I think its a wiring problem.
@RB83L69 thx for the tips- tomorow I will check this next.
Old Dec 8, 2003 | 11:56 AM
german's Avatar
Car: 91`GTA
Engine: 305cui
@RB83L69
A BIG THX to you! It was the f**king connector you sayed. I taked the power now direct from the brown cable and put in on the blower switch- now it works. Not perfect but warm .
Thx again!
Old Dec 8, 2003 | 12:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Glad it was that easy!
sheachopper
Jul 31, 2019 11:27 AM
no green
Jan 9, 2016 09:22 PM
