Weird oil leak
Old Dec 7, 2003 | 08:25 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Weird oil leak
Ok, I was under my car today and noticed oil leaking from the starter bolts. How is this possible? What can I do? I dont want this to toast my new clutch before I get to drive her that far. Thanks in advance.
Bill
Old Dec 7, 2003 | 08:28 PM
llvll4l2c91350's Avatar
check back of the intake, or valve cover.
Old Dec 7, 2003 | 08:49 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
also are u sure it is oil? or water that caught some grease/dirt that looks alot like oil?
looks can be tricky
Old Dec 8, 2003 | 06:27 AM
groundrat's Avatar
Car: 91Z28
Thanks for the replies. It is definately oil. It is not coming from the rear of the manifold. The engine only has 20 minutes on so far( just rebuilt). I will try to get under it to get a picture of it. The oil is only around the bolts not the sides of the starter. Very weird I think. Thanks again.
Bill
Old Dec 8, 2003 | 01:06 PM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
that oill is definatly dripping from the north. Its probably a Valve cover gasket or distributor. If not those, there is three oil Gallery plugs on the back of a SBC- those could be leaking. only way to see that though would be to pull the tranny or engine.
Old Dec 8, 2003 | 01:29 PM
groundrat's Avatar
Car: 91Z28
I will check the pass side valve cover. I did not personally tighten it so I will check. The galley plugs were installed by the machine shop and leak tested. Thanks for the help!!
Billb
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
