T56 swap, slave cylinder spacer?
Old Jun 4, 2002 | 09:51 AM
Chris90Formula's Avatar
I just purchasec a T56 out of 95 camaro and I am planning on swapping it with my T5. The T56 I bought didn't come with the hydraulics for the clutch. I ordered a hydraulic assembly, but my question is with regard to the spacer that goes between the slave cylinder and the bellhousing. Does this spacer come with my hydraulic assembly, or will I have to go to GM and buy one?
Old Jun 4, 2002 | 10:25 AM
jimbuck0's Avatar
It does not come with the Hyd. It should have come with the bellhousing.
Jim Buckingham
Old Jun 4, 2002 | 11:58 AM
Well, I didn't get it with the bellhousing. Do you think that it is availible through GM?
Old Jun 4, 2002 | 02:44 PM
b91z28's Avatar
Car: '91 Camaro Z28
Engine: 5.7L
Yes it is available. I just bought one and they aren't very expensive. I have the part number at home and will post it as soon as I can if someone doesn't beat me to it.
Old Jun 5, 2002 | 11:45 AM
Thats good to hear, thanks b91z28. If you could get me that part number I would really appreciate it.
Old Jun 6, 2002 | 08:54 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Yup, my tranny didn't have it either, it's definitely a separate part, still available new from GM.
Old Jun 8, 2002 | 10:42 PM
b91z28's Avatar
Car: '91 Camaro Z28
Engine: 5.7L
Sorry this has taken me so long to get back to you. The part number is: 12523315 if you go to www.gmpartsdirect.com it is only $19.50
Good Luck, Brandon
Old Jun 9, 2002 | 09:53 PM
BOTTLEDZ28's Avatar
Transmission: A4
you might as well order the 2 bolts that hold it on the bellhousing. they are special bolts that cant be found in any store. the lower bolt will also hold the slave cylinder line as it goes back up the engine.
Old Jun 10, 2002 | 11:04 AM
Thanks guys. I already have the bolts so I just need to order the spacer.
-Chris
Old Jun 10, 2002 | 02:36 PM
IROCracer's Avatar
As I read this post it dawned on me...I KNEW there was supposed to be a spacer there! Dammit, the stupid bastard at the parts counter said he had no idea what I was talking about. I could tell when I was putting my slave on that the threads were clean at a certain point on those studs, that's as far as I tightened the nuts to hold the slave in, it works great, but now I'm all kindsa pissed about it. I knew they wouldn't just leave it open like that. I'm going back there today, I'm gonna rip that guy's ***.
Kelly
Old Nov 14, 2008 | 12:18 PM
92-Formula's Avatar
Re: T56 swap, slave cylinder spacer?
6 years later and this part is discontinued. Anyone know where I can find one?
Old Nov 14, 2008 | 12:37 PM
92-Formula's Avatar
even if some one has the spacers dimensions this would be helpful..
Old Nov 17, 2008 | 10:17 PM
badass91's Avatar
i just converted my car to standard does the t5 have a spacert also
customblackbird
Aug 15, 2021 10:16 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
