Wrong Tach Readings
Old Jan 12, 2001 | 12:59 PM
Ed Z28 350's Avatar
Wrong Tach Readings
My Tach reads incorrectly. At idle, the tach reads 4500 rpm. Press the gas pedal a little and the tach pins itself in the zed zone. Any ideas what would cause this?
Edwin
1986 IROC, 1992 Body Kit, 1989 5.7 IROC Engine, Crane Cam, 3" CVX Exhaust, ADS Superchip, 24# FoMoCo Injectors, Gutted Cat, AFPR (45 psi), Airfoil, 3.42 Gears, MAF Screens removed, Gutted Airbox, K&N Filters
Old Jan 12, 2001 | 06:26 PM
Pat Hall's Avatar
Hmmmmm, could be several things. The tach itself might've gone bad, the needle moved on the shaft so that it's no longer at zero, or the needle is merely stuck. The first thing I would try is remove the instument panel cover and see if you can free up the needle. My tach got stuck once, and that's how I fixed it. If your tach is functioning properly, the needle should go to zero RPM when you turn the key on before actually starting the engine. If it doesn't go to zero when you turn the key on, chances are the needle's probably just hung up.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jan 13, 2001 | 09:03 AM
Ed Z28 350's Avatar
The needle goes to 0 when the car is off. It doesn't look like the needle is twisted around the shaft because the tach completely over-reacts to throttle input. One blip of the throttle from Idle sends the needle from 4000 (the reading I get at idle) to deep in the red zone. I think I need a new tach.
Edwin
Old Nov 27, 2009 | 10:53 PM
Rags91RS's Avatar
Car: 1991 Camaro RS
Engine: 5.0L 305 TBI (L03)
Transmission: TH-700R4
Re: Wrong Tach Readings
I also need an answer to this problem. According to my tach, the 305 in my Camaro RS flys up and over "7 grand" with ease.
Old Nov 27, 2009 | 11:25 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Same with mine at idle its at 2k rpm hopefully you find a way to fix it and tell us how you did it
Old Nov 27, 2009 | 11:40 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
this really belongs in the electonics board, but heres a thread to fix 90-92 tachs, found it with a quick
https://www.thirdgen.org/forums/elec...meter-fix.html
GTAman
Sep 21, 2015 09:57 AM
TheTraut88
Sep 7, 2015 05:22 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
