fuel tank vent valve source
Old Apr 22, 2003 | 01:28 PM
KAOSRacing's Avatar
Is the plastic fuel tank vent valve (GM PN 10033125) a dealer only item or should I be able to get one from any parts house (AutoZone, etc)?
I found that mine is leaking liquid fuel when I pull into my driveway...with about 1/2 a tank in it no less. Hopefully by replacing it my gas smell problem will go away.
Old May 10, 2003 | 12:30 PM
84 Challenge's Avatar
Are you talking about that little breather looking thing that plugs into one end of the fuel line under the tank? My wife's cousin dropped my tank to replace the pump and forgot to put it back on. Stopped a gas station for fuel and started leaking. Plugged it up with vice grips and continued the trip. Not sure if it's a dealer only thing or not.
Brandon
Old May 10, 2003 | 04:08 PM
KAOSRacing's Avatar
That's the piece I'm talking about. I've got one on order from Dal, should be here Monday.
Old May 11, 2003 | 10:44 AM
Vader's Avatar
Ahhh... The infamous "Taco Bell" valve, which, when the diaphragm begins to dry out, exhibits a rather offensive and disgusting noise as the air or fuel vapors are vented into and from the tank.
How pricey was the little sucker?
Old May 11, 2003 | 11:16 AM
KAOSRacing's Avatar
No noise from mine...
Mine's not making a sound but it's allowing liquid fuel out when I'm under 1/2 a tank. No place else on the tank is wet nor can I find evidence of a leak anyplace but after a hard stop, big bump, or pulling into my drive way that valve is wet and sometimes there's even a small pool of liquid gasoline.
I don't have the price yet (price didn't matter, it has to be replaced). I'll have the invoice from Dal when it shows up and let everyone know what it cost.
Old May 12, 2003 | 05:22 PM
KAOSRacing's Avatar
Got it and installed it today. It was $17.72 + S&H from Dal.
Old May 12, 2003 | 06:20 PM
That's not a bad price.
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
