tired of your belt slipping?
We have designed a spring tensioner setup for you all.
We have been making spring tensioners for ATI kits for quite some time...
you can follow news on our latest tensioner for the LS1 guys at LS1tech.com
What blowers are you running? P600B? D series?
How much boost with what blower pulley at what rpm?
Are your engines stock? What mods do you have?
We're thinking of doing a GP. If anyone is interested, please respond with some feedback so we can put some more info together and prices.
Thanks.
Thanks.
I'd like to hear more...
I'll be running a D1SC with 10lbs of boost and I was going to go with a cog set up to eliminate slip but I also don't want my cranks snout breaking off if I go higher than 10lbs...
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
On your guys website http://www.sd-concepts.com when I go to look at your Spring Tensioners link I keep getting a (The page cannot be found) message, I like to see what it's all about.
On a stock engine I'am running a D1SC with a 12 rib 4" pulley and 10Ibs of boost at 5500. I have no slip now but I might slap on this 3.4" pulley that I have and see how that turns out.
2MNYMaros
Sep 15, 2015 11:36 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
