Closed loop timers $8D
Old Dec 30, 2005 | 08:03 PM
JP86SS's Avatar
Did a search and can't find an answer.
The Hacs indicate the time is 1:2, but in all of the XDF ECU's I see the time is 2:1 multiplied.
Code:
; CLOSED LOOP TIMERS
; INDEXED LK UP
L848C:        .byte   0x5F   ;=95 ; 47.5 Sec COLD CLS LP TIMER
L848D:        .byte   0x4B   ;=75 ; 37.5 Sec WARM CLS LP TIMER
L848E:        .byte   0x0F   ;=15 ;  7.5 Sec HOT CLS LP TIMER
XDF's show these calculated at 2x the values, not 1/2.
Is this because those loops are run every other scan?
Has anyone confirmed if the timing is 1:2 or actually 2:1 ?
Old Dec 31, 2005 | 12:47 AM
32V_DOHC's Avatar
At around D2AC engine run time in seconds is loaded and the divided by two. So 180 sec is seen as a number 90. The number is compared to the closed loop timer value.
So the number should be doubled not halved.
HTH
John
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
