Braided trans cooler lines my part # list
Old Jul 6, 2005 | 05:12 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
After searching and not finding much on this topic I thought I would share my part #'s to help others who want to do this. Braided lines aren't the cheapest or easiest way to hook up your trans cooler, using rubber lines is the cheaper easier way to go so this isn't for everyone. I was never happy with the look of the rubber lines I had on it before plus they were getting old and warn so I finally converted over to braided lines. I cut off the stock steel lines just after the front of the engine and used a compression fitting to convert the 5/16 steel line to 6AN braided. The trans cooler is mounted(fittings facing upward) in front of radiator bolted to the bottom part of the frame just behind the nose piece. My old cooler was mounted(fittings facing toward passenger side) closer to the radiator but the new one wouldn't fit in the same place. 90* hose ends were used on the cooler to allow for clearance of the plastic trim piece that covers everything(pics show it being off). The B&M cooler I used required a 1/2" NPT to 6AN fitting to hook up the hose ends to it. All Fittings are Earls.
165056 Tube Adpt 6AN male to 5/16 tube (2)
800106 6AN straight Hose end (2)
809106 90* swivel 6AN hose end (2)
AN816-6-8D 6AN to 1/2" NPT Adapter (2)
300006 6AN hose (5ft)
70266 B&M Trans Cooler
Old Jul 6, 2005 | 05:13 PM
jbenge's Avatar
Another pic of the cooler, not sure this is the best location but I think it allows for the easiest access to everything.
Old Jul 6, 2005 | 05:14 PM
jbenge's Avatar
one more pic showing the compression fittings
Old Jul 6, 2005 | 09:58 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Looks good, nice and clean. I went with rubber on my tranny cooler but will go braided lines upon my return in 6 months. Thanks for the part #'s.
Old Apr 29, 2014 | 07:41 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Axle/Gears: 4th gen 3.42
Re: Braided trans cooler lines my part # list
This is exactly what I was thinking of doing! thanks jbenge!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
