Twin Turbo Kit.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Twin Turbo Kit. (PICS)
Selling my twin turbo kit.
Kit comes with two modified s10 headers
Two t3 thunder bird turbos modified by majestic turbo.
One turbo is freshly rebuilt the other has about 3000 miles on it.
Two down pipes.
One intercooler dimentions are 24,12,3 (brand new never used)
This kit put a stock iroc with stealth ram into the twelves without issuses.
Selling due to new house purchas.
Would like to get 900 bucks. Turbos cost like 600 bucks alone. but open to offers.
Two down pipes.
Car: whatever has the most gas in it
Engine: GM v8
Transmission: Uumm that's contingent
Axle/Gears: See prior line
please send pics to
janderson1@citistreetonline.com and
cyclerage23@yahoo.com
Do you have any of the other plumbing?
thanks.
thanks.
Want a title? Post!
Car: 2003 VW Jetta Wolfsburg
Engine: 1.8T
Transmission: Whatever they put in 'em
I'd be interested in seeing some pics too... please send to threetwentyseven@hotmail.com
Car: 91 t/a gta
Engine: 383
Transmission: t-56
Axle/Gears: moser/auburn/410
pics to skifur555im666@comcast.net thanks, jamie
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
please send pics to timbo121212@aol.com thanks is the cold side piping included?
i would also like to see some pics. Send them to bryan_camaro@hotmail.com. Is there any wastegates or BOV with the kit and is the cold piping included?
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
im like everyone else. send pics to bonenct@aol.com
I'd like pics too, PPRracing@comcast.net
Car: 89 Camaro Iroc-Z
Axle/Gears: 3.42 7.625 10 bolt
I imigine those turbos are gone with all of the people that were interested in them, but if you could reply back eithery way that would be great.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I will try and dig up some pics of it installed. All I can say is I dont think it will work with a/c. But as far as where the turbos sit. They sit towards the front of the motor. And are at a little bit of an angle.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Sorry cant find pics of it on the car. All I can say is that I was running a v belt alternator and no ac.
Car: 1986 Trans Am
Engine: Carb'd 305
Axle/Gears: 10 bolt, 3:42's
This setup still for sale?
What else would be needed to complete this setup. (oil/coolant lines, piping, boost controller, wastegates, etc....)
What RPM's approx did the turbos spool on your stock iroc?
Thanks,
Shawn
Thanks,
Shawn
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Yes this set up is still for sale. What you would need to complete the set up.
Intercooler pipeing
Two waste gates
One blow off valve
As for a boost controller you can buy a manual for like 20 bucks off ebay.
The turbos would spool at about 2500 rps. I would see full boost at 3200 to 3400.
Intercooler pipeing
Two waste gates
One blow off valve
Car: 1986 Trans Am
Engine: Carb'd 305
Intercooler pipeing
Two waste gates
One blow off valve
Intercooler pipeing
Two waste gates
One blow off valve
So by looking at the headers the wastegate flanges are right behind the turbo flanges correct? And then what is the flange on the downpipe, egr? I'm very interested just trying to see exactly what you have.
Do you know what shipping would be to Holt, MI or Lima, OH (doesn't matter which one, whatever is cheapest)? I'd like to pick up the whole setup for like $850 shipped if you'd let it go for that.
Thanks,
Shawn
Car: 1986 Trans Am
Engine: Carb'd 305
Just want to make sure...these headers will bolt up to my 305 correct? I don't know if TPI heads are different and maybe this is what this setup was for thats why I'm asking...I don't know a lot about sbc's.
Also, what is the brass colored fitting for on the turbos?
Shawn
Shawn
Car: 1986 Trans Am
Engine: Carb'd 305
Originally posted by porkyzilla
the turbo's are rear mount?? what make of headers are those?
Shawn
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
The brass fiting is the oil drain for the turbo. This kit should work with any small block chevy.
Car: 1986 Trans Am
Engine: Carb'd 305
I'm just trying to figure out exactly everything I'll need to make this work because I am on a tight budget.
Shawn
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Originally posted by dbtk2
Thats what I thought it was. So it would need an oil supply and return (drain) line as well for each turbo. Where did you get your oil supply from and where did you connect the drain to? And it would probably need coolant lines as well, or are these turbos not water cooled?
Shawn
Shawn
Kevin
Car: 87, 88 and 89 Iroc-Z
Engine: 305, and 350
Transmission: 700R, and T-5
Axle/Gears: 3:23 POSI
im interested in these please pm with final price and any other info i should need i want to know if you will trade for these.
Car: 1988 Iroc-Z and 1985 Z28
Engine: Mild TT 355 and Built 383 Superchar
Transmission: Manual
Why are you not including any plumbing or intake piping or waste gates? Where is the rest of the parts? If you ran it on that Iroc, you would have the rest of the parts. To me it looks like a project that was never finished.
Dont get me wrong, this is a good deal, but something is fishy about not having the rest of the parts. Give more info to the people.
Just lookin out for fellow thirdgener's
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Ok,
Fishy.... I dont think so. FlamedIroc is local and has seen the parts and can vouch for what I am selling. Yes the project was not finnished. I bought this turbo kit with the intention of using it on my car. Well fundage for my car is not good enough to do what I want. There is to much my car needs to worry about the turbo kit. Thus the reason I am selling it. The person I bought it from built a huge turbo kit thus he kept the intercooler and some of the parts for the turbo kit he was using. I paid way more for this then what I am selling it for. I just want to drive my car again.
Fishy, I dont think so. I have been a part of thirdgen.org for a while now. I dont screw people over. Ask anyone who has delt with me.
Sorry I sold the intercooler all ready.
Originally Posted by FlamedROC
intercooler? Still wanna sell it?
