what about the 305 vortec heads
Car: 1989 Camaro RS
Engine: 305 stock, soon 383 stroker
Transmission: stock 700R4, but also soon aftertmarket
What about using the 305 votec heads? < casting number101081 >.Obviously they wont have the numbers as the ones used in CHP becasue of valve size but how much tuning would that lesson?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: what about the 305 vortec heads
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
get the world products for your 305. not vortec
http://www.jegs.com/cgi-bin/ncommerc...41&prmenbr=361
Car: '90 RS
Engine: 377 LSX
What was the hp on the 305 vortec engine. I bet it was more than the LO3 it replaced. It wasn't just the port fuel injection either. I don't know how good the heads are but I bet they are better than the stock LO3 heads, probably a close match for the 305 tpi heads. If I remember correctly the 305 vortec made about 230hp and that was with a very mild came compared to the biggest 305 tpi cam which made 235hp with a SD system and dual cats.
Steve
Steve
Car: '90 RS
Engine: 377 LSX
Steve
Steve
Car: '90 RS
Engine: 377 LSX
Car: 1989 Camaro RS
on the S/r Torquer heads..can i use the pre 87 bolt pattern on my 89 305 block? will htis just affect my manifold and acc. choices?
Car: '90 RS
Engine: 377 LSX
Car: 1989 Camaro RS
incase you guys couldnt tell this is my first engine rebuild, hop up what ever. i bought an 89 camaro RS with a spotless interior and exterior and 92K on the engine for a grand. i went with it becasue i heard SBC were a dime a dozen and parts are cheap. i htought it would be a good car start with. i appreciate all the help
Car: 1989 Camaro RS
shifty, the reason i ask is because i have to offers at a set of bare pre 87 castings cheap. and the later 87 castings are more expensive new. as long as i go with the right manifold and valve covers will the older ones work?
Car: '90 RS
Engine: 377 LSX
Car: 1989 Camaro RS
so will the cost and work of converting to an older valve train worth it to save say $100 bucks on the heads?
Car: '02 Z06
Engine: L33 5.7
Originally posted by ShiftyCapone
Better yet is to get some 416's or 081's.
are they better then the world torqers?
whats the max lift? i need specs! lol
Car: '90 RS
Engine: 377 LSX
Car: 1989 Camaro RS
can you give me the whole csting number so i can start looking for them... man you guys are great..heh
Car: '90 RS
Engine: 377 LSX
what are 416 and 081?
The 081 are the 305 TPI heads. the 416 are the older pre 87 305 heads found on just about every f-body and GM car. There were found on HO cars, L69 cars, monte's ect. Any mid 80's 305 car pretty much had them. They are limited to .480 lift like any other GM casting. They can however be fitted with larger valves and perform awesome with some port work. You can usually do all of that for less than the Worlds out the door.
Car: '90 RS
Engine: 377 LSX
Car: 1989 Camaro RS
dumb question..but you guys are being very patient with me.. my camaro has TBI it wont have the 081 catings will it?
Car: '90 RS
Engine: 377 LSX
Car: '02 Z06
Engine: L33 5.7
hey chaotic, i think we got the exact same cars
89 rs tbi's.
maybe we can make this a project for both of us.. to get new heads and see gains.
of the two. 416 or 081.. what is better?
and you would just need new valves, we can get a new max lift? cuz the cams im looking at have over that lift.
Grind: 270
Lift: .495''/.502''
RPM Range: 1600-5400
Grind: 82
Lift: .510''/.520''
RPM Range: 2200-5800
of coarse, i know only basic cams and what the lift is. i just assume bigger is better.
and the higher rpm range means choppier idle?
but not lets get off track.
except for maybe answering that rpm range question
89 rs tbi's.
Grind: 270
Lift: .495''/.502''
Grind: 82
Lift: .510''/.520''
Car: 1989 Camaro RS
if i get a set of tpi heads from a wreck yard i can take them to a machine shop, have them ported, what spring work should i have done?
Car: '90 RS
Engine: 377 LSX
Car: 1989 Camaro RS
i bought this car a year ago a week before i deployed to afghanistan. now the money i saved is buring a whole in my pocket. heh.....TraviZ what are your plans with yours?
Car: '02 Z06
Engine: L33 5.7
by the end of summer, i want headers-3"y pipe to cutout, heads, cam and intake manifold, read my sig, i havnt done much. i just got the cutout valve waiting to be installed.
i also have a zex nitrous kit im modding to fit the tbi. but im not rushing it cuz i dun wanna *** anything up
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
By the way I have looked at 350 and 305 vortec heads side by side. The only difference is intake valve size and chamber size. The chamber is shaped the same, the ports are identical, etc. I have heard they only flow about 6% less than the equivalent 350 vortec head. It would be interesting to see someone flow a stock head. The vortec 305 was rated 230 hp and 290 ft/lbs vs the 350s 255 hp and 330ft/lbs. The vortec 305 usually had single cats and the 350 duals.
Car: 1989 Camaro RS
Well now i cant decide between S/R Torquer 305 heads, and Vortec 305 heads. hmmm....
Car: '02 Z06
Engine: L33 5.7
sounds like worlds would be easier bolt on, and with some port polishing, it would be a real good deal.
even though we need every ounce of hp out of our 305's
maybe i will get worlds, u get the vortecs and we can see what happens
Car: 91 Camaro RS Convertible
Transmission: 5-Speed
Go with the Worlds over 305 vortecs any day. Remember too, that if you get vortec heads you need a matching vortec intake manifold which usually run about $300. Keep that in mind, go with the Worlds or a set of 081's.
With the vortecs you'll lose the egr function unless you use the vortec tbi intake and external egr kit. As for other vortec intakes they range anywhere from $180 to $270. If you were to use the vortec heads you could go with an Edelbrock performer carb intake and a tbi to carb adapter. If the heads are cheap enough then the cost with the intake would be close if not cheaper than the World heads.
Steve
Steve
Car: '90 RS
Engine: 377 LSX
the increased outcome prolly wouldnt justify the price as if you just went with worlds right?
Car: 1989 Camaro RS
actually im working out a deal on some 801's that have been ported and polished and have new springs studs and rocker arms. depends on how much he wants
Car: '90 RS
Engine: 377 LSX
Car: '90 RS
Engine: 377 LSX
did the 801s only come on post 87 tpi motors?
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Grind: 270
Lift: .495''/.502''
Grind: 82
Lift: .510''/.520''
Um....you guys live in Cali? Don't you have emissions there too? Lift might be a little high to pass the sniffer don't you think?
Max I have seen for 50 state legal is like .480(?)
Lift: .495''/.502''
Grind: 82
Lift: .510''/.520''
Car: '02 Z06
Engine: L33 5.7
i think withgood tuning it w*ould pass. but i would really prefer the 270grind.
i would love the 82 grind, but that is a lil extreme.
Car: '90 RS
Engine: 377 LSX
Don't worry so much about the lift. What is the duration and LSA on those cams? Lift is important but not as much as overlap and duration. That will ultimately determine tunability and idle quality.
where do you guys get your data on 305 vortec heads? i have not seen any flow numbers or performance data in any of these posts yet everyone repeats that they suck.
My buddy chrisformula355 must have a magic set then because he was going mid-high 12s with them
if you dont want them ill gladly take them and i have a pretty nice set of 416s
Car: '02 Z06
Engine: L33 5.7
Grind: 270
Lift: .495''/.502''
270-276 adv dur
Grind: 264
Lift: .487''/.495''
RPM Range: 1200-5200
260-264 adv dur
Grind: 82
Lift: .510''/.520''
282-288 adv dur
please tell me that 264 grind will work. i like that one best
Lift: .495''/.502''
270-276 adv dur
Grind: 264
Lift: .487''/.495''
260-264 adv dur
Grind: 82
Lift: .510''/.520''
282-288 adv dur
Car: '02 Z06
Engine: L33 5.7
no problem.
Grind: 270
Lift: .495''/.502''
218-224 @ .050"
Grind: 264
Lift: .487''/.495''
212-218 @ .050"
Grind: 82
Lift: .510''/.520''
230-236 @ .050"
the LSA on all three is 110degrees
Grind: 270
Lift: .495''/.502''
218-224 @ .050"
Grind: 264
Lift: .487''/.495''
212-218 @ .050"
Grind: 82
Lift: .510''/.520''
230-236 @ .050"
If you're a novice tuner, look elsewhere. Those 110's will hurt to tune for a beginner. Look for decent duration in the area of that 264 grind and at least a 112 Lobe separation.
no problem.
Grind: 270
Lift: .495''/.502''
218-224 @ .050"
Grind: 264
Lift: .487''/.495''
212-218 @ .050"
Grind: 82
Lift: .510''/.520''
230-236 @ .050"
no problem.
Grind: 270
Lift: .495''/.502''
218-224 @ .050"
Grind: 264
Lift: .487''/.495''
212-218 @ .050"
Grind: 82
Lift: .510''/.520''
230-236 @ .050"
Car: '02 Z06
Engine: L33 5.7
i am getting the world torqer's, port and polished, the edelbrock tbi intake manifold, 1.6rockers, i got the open element, headers, 3" y pipe through highflow cat to cutout valve. and either 3.42 or 3.73 gears.
