what about the 305 vortec heads
Old May 23, 2004 | 06:43 PM
  #51
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by khaotic
if you shave .0050 off a 801 what cc will the head be?
~Rusty
Do you mean an 081 head? Why do you want to shave anything off. 9.3:1 is plenty of compression for a 305. if you want more it is cheaper and easier to go with a thinner head gasket.
Old May 24, 2004 | 09:31 AM
  #52
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
You can use more that 9.3:1 on a 305. Mine is 9.54:1.
By the way the "801 is a 305 head almost Identical to the 601.
Old May 24, 2004 | 12:37 PM
  #53
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Oh I know. You can go as high as you want really. Once you get past 9.6:1 you do not want to use thin head gaskets.
Old May 24, 2004 | 10:58 PM
  #54
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
im at 10:1, thin head gaskets, no problems so far and a couple 1000 miles and dozens of drag passes
Old May 24, 2004 | 11:13 PM
  #55
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
How thin? I know of a few people who blew their .015's with 9.6:1. I would love to run a thin head gasket with someshaved heads but I am to leary.
Old May 25, 2004 | 08:59 AM
  #56
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
It's called steel wafer gaskets like my 305 came with from the factory. They are very thin almost like the copper head gaskets.
Old May 26, 2004 | 05:20 AM
  #57
Joshua's Avatar
I use the Fel-Pro 1094 .015" shim with ~10.6 compression and have had no problems.
Old May 28, 2004 | 09:32 AM
  #58
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Wow! I am impressed.
Old May 28, 2004 | 11:57 PM
  #59
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
1094 steel shim here 10:1, 6000 rpm shifts and scores of drag runs. No problems. Even driven through the mountains and that really put a load on the engine considering its not exactly a low end torque monster and its been fine.
Old May 29, 2004 | 12:28 AM
  #60
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Weren't at 5000+ RPMs carving the corners?
Old May 29, 2004 | 08:10 PM
  #61
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
its a drag car, i was trying to keep it from flying off a cliff at 15 mph
btw not to start a politics debate but dont your sig line and choice of candidate clash? after all Nader is a centrist and thinks there should be govt regs on everything
Old Jun 23, 2004 | 06:41 PM
  #62
YenkoZL1's Avatar
Car: 1991 RS Camaro
Engine: Custom Built 327
Transmission: Tremec 5-speed
khaotic
khaotic
I would go with S/R 305 over the 305 Vortecs. Its less of a hassel and they do the job. They only thing I recomend is that you get a vavle job done to them. The casting isnt that great. But once a 3-angle valve job is done they'll be ready roll. I have the S/R Torquers on my car (2.02 valves) and the guy who does my machine work said it was one of the worse castings he's ever seen. But they're still a great replacement head. They just need some messaging.
Old Jun 23, 2004 | 09:05 PM
  #63
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
a 305 world head is hardly better than a stock 416 and ported 416s blow it out of the water. Considering youd save alot of money on the heads you could have them ported and all the machining you need or if you are like me you port them yourself with no prior experience and save even more money and gain more satisfaction when your car is almost in the 12s
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
