Weight of cast heads?
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I need the weight of cast 041 heads as I have to get a shipping quote.
Cast? Do you mean "cast iron" or "cast aluminum"?
A bare '993 cast iron head weighs 46.2 lbs. That's with no valves, springs, studs, retainers, bolts, sensors, etc. - just the bare casting.
A "fully-prepped" head weighs in at 61.4 lbs. That's over 15 lbs, of rockers, *****, studs, nuts, valves, springs, retainers, keepers - everything but the 17 head bolts.
Incidentally, the same '993 head after bowl and runner porting, chamber polishing, port matching, and core shift/mold flash cleanup weighs in at 42.8 lbs. That's 3.4 pounds of unnecessary iron that only inhibits flow...
I would imagine that since the '041 heads are presumed to be a better casting, they might start out a little lighter.
Car: 1986 Iroc
Thanks for the replies. Yes they are cast iron and complete. I will base the quote on 120lbs and that should be close.
84z96L31vortec
Aug 20, 2017 12:16 AM
gixxer92
Sep 1, 2015 04:32 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
