ZZ4 cam with "stock" TPI
Old Apr 27, 2003 | 09:06 PM
KYL98's Avatar
Car: 1991 Z28
I have recently rebuilt a 350 4bolt to put in my 91 Z. Its a 355 with corvette L98 heads, and has a ZZ4 cam in it with 1.6rr. My question is....do I need bigger injectors for this cam? It idles and drives fine..so I dont think I need a different PROM, but it just seems like it leans out on the higher side of the RPM. I know that TPI's die out about 4500, but this motor just seems like it wants more fuel? Would a adj fuel reg. fix this? The 02 sensor confirms the leaning, but its kinda old and needs to be replaced.....any help would really be great. Thanks...
Old Apr 27, 2003 | 09:43 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Replace the O2 sensor. Aside from that, have you done a general tune up recently in regards to your ignition and fuel injection system, fuel pump and otherwise?
It could be one of these simple/cheap things before you decide you might need to bump fuel pressure &/or edit the prom.
Old Apr 27, 2003 | 09:50 PM
KYL98's Avatar
Car: 1991 Z28
Yes I just did a tune up about a week ago....I used Ac Delco plugs(.045)...Taylor wires, MSD distributor, coil, cap and rotor(timing set at 28* adv at 3000rpm). The car also has a new Holley fuel pump and a K&N fuel filter. The injectors came from a 90 Vette TPI, but they are 22lb right? Im almost certain thats what mine originally had. Ill change the 02 sensor in the morning....dont know why I didnt change it to begin with.....
Old Apr 28, 2003 | 12:19 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
22# inj's should be plenty for that cam. You sure they are clean and flowing correctly???
Old Apr 28, 2003 | 01:37 AM
bigals87z28's Avatar
Car: Check The Sig
with a modded motor, you cant really go wrong with an afpr, there a good tool for tunning.
Old Apr 28, 2003 | 03:56 PM
KYL98's Avatar
Car: 1991 Z28
well...I changed the 02 sensor today....and also got a new afpr...from TPIS....I set it to 50psi like they said...and drove it down the Interstate...it runs great now. I havent had a chance to check the 02 sensors reading, but it seems right now....and smells right if that makes sense. Also, just wondering how much my 170deg t-stat affects the mixture??? It definitely seems better though......
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
